Sega Game Gear Case Replacement
    1. Sega Game Gear Case Replacement, Battery: step 1, image 1 of 1
      • Place your device upside down and locate the two battery compartments.
      Ask FixBot
    2. Sega Game Gear Case Replacement: step 2, image 1 of 1
      • Press on the tabs at the bottom of the battery covers then lift up to remove.
      • Remove batteries if they are present.
      Ask FixBot
    1. Sega Game Gear Case Replacement, Case: step 3, image 1 of 1
      • Remove the following screws:
      • Six Phillips screws
      • One 4.5 mm Gamebit screw
      Ask FixBot
    2. Sega Game Gear Case Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to take all other screws out.
      Ask FixBot
    3. Sega Game Gear Case Replacement: step 5, image 1 of 2 Sega Game Gear Case Replacement: step 5, image 2 of 2
      • Gently open the case by unfolding it over the top of the Sega Game Gear.
      • Do not pull the back of the case away, as cables are connected between both sides.
      Ask FixBot
    4. Sega Game Gear Case Replacement: step 6, image 1 of 3 Sega Game Gear Case Replacement: step 6, image 2 of 3 Sega Game Gear Case Replacement: step 6, image 3 of 3
      • Carefully unplug the 2 white-tipped connectors on the top cover.
      Ask FixBot
10 other people completed this guide.
Lauren Thurston
506 Reputation
3 Guides authored
Cal Poly, Team 28-33, Regan Spring 2010 Member of Cal Poly, Team 28-33, Regan Spring 2010
CPSU-REGAN-S10S28G33
5 Members
72 Guides authored
1 Guide Comment
Is this guide made to help replacing the Game Gear shell? Almost doesn't seem like a thorough guide, I'm still seeing screws on the motherboard in the last photo, I assume those get taken out too?
Alex Tomalty - Reply Share
Past 24 Hours: 2
Past 7 Days: 30
Past 30 Days: 124
All Time: 22,809
