Sega Dreamcast Power Supply Replacement
    1. Sega Dreamcast Power Supply Replacement, Expansion Bay: step 1, image 1 of 2 Sega Dreamcast Power Supply Replacement, Expansion Bay: step 1, image 2 of 2
      • Verify that the console is disconnected from the AC outlet before you begin.
      • Flip the console over on its back.
      • Take note of your model number, in case replacement parts are needed.
      Ask FixBot
    2. Sega Dreamcast Power Supply Replacement: step 2, image 1 of 3 Sega Dreamcast Power Supply Replacement: step 2, image 2 of 3 Sega Dreamcast Power Supply Replacement: step 2, image 3 of 3
      • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
      Ask FixBot
    1. Sega Dreamcast Power Supply Replacement, Top Cover: step 3, image 1 of 1
      • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
      • Note: Remove the expansion bay to locate the fourth screw
      Ask FixBot
    2. Sega Dreamcast Power Supply Replacement: step 4, image 1 of 1
      • Internal components can be loose. Be careful that they do not fall out when removing the cover.
      • Turn the console right side up.
      • Remove the top cover by gently lifting the upper portion of the console.
      Ask FixBot
    1. Sega Dreamcast Power Supply Replacement, Power Supply: step 5, image 1 of 2 Sega Dreamcast Power Supply Replacement, Power Supply: step 5, image 2 of 2
      • Unplug the device from the outlet. If you have just powered off the system, allow a few minutes for the capacitors to discharge before you begin working.
      • Remove the white female pin head by pinching and lifting directly up on the harness.
      • Remove the two Philips #02 screws from the board.
      • Remove the power board. Using both hands, gently lift the power board away from the console without damaging the male pin head
      Ask FixBot
    2. Sega Dreamcast Power Supply Replacement: step 6, image 1 of 2 Sega Dreamcast Power Supply Replacement: step 6, image 2 of 2
      • Remove the unit. Carefully remove the power board from the console by lightly grasping the board by the edge and lifting directly upward.
      • Remove the two 10mm #02 Philips screws to detach the switch module from the console.
      • Purchase a replacement power board.
      Ask FixBot
6 other people completed this guide.
Jacks216
103 Reputation
1 Guide authored
Cal Poly, Team 5-1, Regan Fall 2009 Member of Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Members
109 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 38
Past 30 Days: 195
All Time: 19,917
