Up to 20% off select tools
Sega Dreamcast GD-ROM Replacement
Views: 41K
View statistics:
Past 24 Hours:
9
Past 7 Days:
74
Past 30 Days:
338
All Time:
40,645
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
This guide details how to replace a failed GD-ROM drive with a new working drive.
Be sure to replace the GD-ROM with one corresponding to your model number. Refer to the Top Cover Disassembly Guide for instructions on where to find your model number.
Problem with this guide: The photos incorrectly show the power supply has been removed.
    1. Sega Dreamcast GD-ROM Replacement, Expansion Bay: step 1, image 1 of 2 Sega Dreamcast GD-ROM Replacement, Expansion Bay: step 1, image 2 of 2
      • Verify that the console is disconnected from the AC outlet before you begin.
      • Flip the console over on its back.
      • Take note of your model number, in case replacement parts are needed.
      Ask FixBot
    2. Sega Dreamcast GD-ROM Replacement: step 2, image 1 of 3 Sega Dreamcast GD-ROM Replacement: step 2, image 2 of 3 Sega Dreamcast GD-ROM Replacement: step 2, image 3 of 3
      • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
      Ask FixBot
    1. Sega Dreamcast GD-ROM Replacement, Top Cover: step 3, image 1 of 1
      • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
      • Note: Remove the expansion bay to locate the fourth screw
      Ask FixBot
    2. Sega Dreamcast GD-ROM Replacement: step 4, image 1 of 1
      • Internal components can be loose. Be careful that they do not fall out when removing the cover.
      • Turn the console right side up.
      • Remove the top cover by gently lifting the upper portion of the console.
      Ask FixBot
    1. Sega Dreamcast GD-ROM Replacement, GD-ROM: step 5, image 1 of 2 Sega Dreamcast GD-ROM Replacement, GD-ROM: step 5, image 2 of 2
      • Detach the orange cable by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
      Ask FixBot
    2. Sega Dreamcast GD-ROM Replacement: step 6, image 1 of 2 Sega Dreamcast GD-ROM Replacement: step 6, image 2 of 2
      • Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
      Ask FixBot
    3. Sega Dreamcast GD-ROM Replacement: step 7, image 1 of 2 Sega Dreamcast GD-ROM Replacement: step 7, image 2 of 2
      • Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket.
      • The console is rotated 90 degrees counter-clockwise in the first photo. The second photo depicts the normal position.
      Ask FixBot
    4. Sega Dreamcast GD-ROM Replacement: step 8, image 1 of 2 Sega Dreamcast GD-ROM Replacement: step 8, image 2 of 2
      • When lifting the GD-ROM, be careful that the top half of the casing does not detached from its base.
      • Remove the GD-ROM by gently lifting it from its base.
      Ask FixBot
    1. Sega Dreamcast GD-ROM Replacement, GD-ROM: step 9, image 1 of 2 Sega Dreamcast GD-ROM Replacement, GD-ROM: step 9, image 2 of 2
      • Replace the bad GD-ROM drive with a functional one.
      Ask FixBot
    2. Sega Dreamcast GD-ROM Replacement: step 10, image 1 of 2 Sega Dreamcast GD-ROM Replacement: step 10, image 2 of 2
      • Secure the new GD-ROM drive to the console with the Philips #2 screws.
      Ask FixBot
    3. Sega Dreamcast GD-ROM Replacement: step 11, image 1 of 3 Sega Dreamcast GD-ROM Replacement: step 11, image 2 of 3 Sega Dreamcast GD-ROM Replacement: step 11, image 3 of 3
      • Connect the three GD-ROM cables to the logic board.
      • Connect the GD-ROM data ribbon to the logic board.
      Ask FixBot
Finish Line
10 other people completed this guide.
Author
with
Thorr686
528 Reputation
2 Guides authored
Cal Poly, Team 5-1, Regan Fall 2009 Member of Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Members
108 Guides authored
2 Guide Comments
If only it was that simple Sega screwed U.K gamers over with the fact we have to buy totally new consoles due to the wires of the disk drive being soldered in rather than clipped in.
Anthony Salmon - Reply Share
My HKT-3020 console, NTSC-U revision 1, manufactured in Japan during 4/2000, does not have the orange cable shown in step 5. I was able to skip steps 5 and 6, and for step 7 I had to remove 3 screws, not 2. My GD-ROM drive came as an assembly, mounted on a metal plate; the entire assembly simply lowers into a connector port. After removing the screws, I just had to gently wiggle it up and out of the port, then lower the replacement assembly into the same port, and replace the 3 screws.
Aaron Teplitsky - Reply Share
Past 24 Hours: 9
Past 7 Days: 74
Past 30 Days: 338
All Time: 40,645
