Sega CD CD Tray Replacement
Views: 11K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
71
All Time:
11,370
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Sega CD CD Tray Replacement, Sega CD Plastic Housing Removal: step 1, image 1 of 2 Sega CD CD Tray Replacement, Sega CD Plastic Housing Removal: step 1, image 2 of 2
      • Using a Phillips head screwdriver remove six screws from the bottom of the console.
      • The six screws are marked.
      Ask FixBot
    2. Sega CD CD Tray Replacement: step 2, image 1 of 1
      • Remove the two screws that attach the Genesis' connector to the rest of the console.
      • The two screws are marked in the diagram.
      Ask FixBot
    3. Sega CD CD Tray Replacement: step 3, image 1 of 1
      • Slide the lock tab to the left to separate the halves of the console.
      Ask FixBot
    4. Sega CD CD Tray Replacement: step 4, image 1 of 1
      • Lift from the left side to remove the top of the case.
      Ask FixBot
    5. Sega CD CD Tray Replacement: step 5, image 1 of 1
      • Using the spudger, pry the cover off of the Genesis attachment.
      Ask FixBot
    6. Sega CD CD Tray Replacement: step 6, image 1 of 1
      • Lift the top of the case to remove the cover.
      Ask FixBot
    7. Sega CD CD Tray Replacement: step 7, image 1 of 1
      • Remove the faceplate by pulling it up, then out.
      Ask FixBot
    1. Sega CD CD Tray Replacement, CD Tray: step 8, image 1 of 2 Sega CD CD Tray Replacement, CD Tray: step 8, image 2 of 2
      • Remove metal plate by unscrewing the three screws with the Phillips head screwdriver and then lifting the plate.
      • The three screws are shown on the diagram.
      Ask FixBot
    2. Sega CD CD Tray Replacement: step 9, image 1 of 2 Sega CD CD Tray Replacement: step 9, image 2 of 2
      • Remove the two screws from the plastic bar.
      • The two screws are shown pictured.
      Ask FixBot
    3. Sega CD CD Tray Replacement: step 10, image 1 of 2 Sega CD CD Tray Replacement: step 10, image 2 of 2
      • To remove the CD tray
      • Remove the four screws with the Phillips head screwdriver.
      Ask FixBot
    4. Sega CD CD Tray Replacement: step 11, image 1 of 1
      • Carefully unplug the wire connected to optical reader.
      Ask FixBot
    5. Sega CD CD Tray Replacement: step 12, image 1 of 2 Sega CD CD Tray Replacement: step 12, image 2 of 2
      • Remove the four screws on the underside of the CD tray with a small Phillips head screwdriver.
      • The four screws are highlighted on the diagram.
      • The four springs below the circuit board are attached to the screws, so be careful not to lose them when you remove the screws.
      Ask FixBot
    6. Sega CD CD Tray Replacement: step 13, image 1 of 1
      • Carefully remove the CD tray from circuit board.
      Ask FixBot
2 other people completed this guide.
sskyllin
27 Reputation
2 Guides authored
Cal Poly, Team 5-14, Maness Fall 2010 Member of Cal Poly, Team 5-14, Maness Fall 2010
CPSU-MANESS-F10S5G14
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 71
All Time: 11,370
