Up to 20% off select tools
Seal Maintenance
Views: 2.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
109
All Time:
2,504
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Seal Maintenance
Introduction
Go to step 1 ↓
If your blender is leaking food the problem could be the seal on top of the cup. It could either be dislodged or torn, This guide will show you how to fix the seal if it is dislodged, and to replace it if it is torn,
    1. Seal Maintenance, Seal Maintenance: step 1, image 1 of 1
      • Inspect your seal to see if it is loose or if there is any damage.
      Ask FixBot
    2. Seal Maintenance: step 2, image 1 of 1
      • Pull your seal off from the top.
      Ask FixBot
    3. Seal Maintenance: step 3, image 1 of 1
      • Line the new seal on the grooves.
      Ask FixBot
    4. Seal Maintenance: step 4, image 1 of 2 Seal Maintenance: step 4, image 2 of 2
      • Push down the seal until it is secured into the top.
      Ask FixBot
Author
with
Kamal Taha
679 Reputation
5 Guides authored
USF Tampa, Team 1-3, Sullivan Fall 2015 Member of USF Tampa, Team 1-3, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G3
3 Members
60 Guides authored
1 Guide Comment
Could you post instructions for matching what grooves go where. May be a silly request but I'm having trouble with it.
Brian Compton - Reply Share
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 109
All Time: 2,504
