Scuf Reflex Thumbsticks Replacement
    1. Scuf Reflex Thumbsticks Replacement, Pry up the right faceplate trim edge: step 1, image 1 of 3 Scuf Reflex Thumbsticks Replacement, Pry up the right faceplate trim edge: step 1, image 2 of 3 Scuf Reflex Thumbsticks Replacement, Pry up the right faceplate trim edge: step 1, image 3 of 3
      • The faceplate trim is secured by plastic clips.
      • At the bottom tip of the right grip, insert the flat end of a spudger or a clean fingernail between the faceplate trim and the back cover.
      • Pry up to release the faceplate trim’s bottom right clip.
      Ask FixBot
    2. Scuf Reflex Thumbsticks Replacement, Pry up the left faceplate trim edge: step 2, image 1 of 3 Scuf Reflex Thumbsticks Replacement, Pry up the left faceplate trim edge: step 2, image 2 of 3 Scuf Reflex Thumbsticks Replacement, Pry up the left faceplate trim edge: step 2, image 3 of 3
      • At the bottom tip of the left grip, insert the flat end of a spudger or a clean fingernail between the faceplate trim and the back cover.
      • Pry up to release the faceplate trim’s bottom left clip.
      Ask FixBot
    3. Scuf Reflex Thumbsticks Replacement, Pry up the center of the faceplate trim: step 3, image 1 of 2 Scuf Reflex Thumbsticks Replacement, Pry up the center of the faceplate trim: step 3, image 2 of 2
      • Insert the flat end of a spudger between the faceplate trim and the back cover, next to the headphone jack.
      • Pry up to release the plastic clips securing the center of the faceplate trim.
      Ask FixBot
    4. Scuf Reflex Thumbsticks Replacement, Remove the faceplate trim: step 4, image 1 of 3 Scuf Reflex Thumbsticks Replacement, Remove the faceplate trim: step 4, image 2 of 3 Scuf Reflex Thumbsticks Replacement, Remove the faceplate trim: step 4, image 3 of 3
      • The top corners of the faceplate trim are slotted up underneath the faceplate.
      • Lift the bottom edge of the faceplate trim and thread it up and over the thumbsticks.
      • Pull the top corners of the faceplate trim out from underneath the faceplate and remove the faceplate trim.
      • To reinstall the faceplate trim, slide its top corners under the faceplate and over the thumbsticks, then push down along the edges of the trim to engage the clips securing it.
      Ask FixBot
    1. Scuf Reflex Thumbsticks Replacement, Remove the thumbsticks: step 5, image 1 of 3 Scuf Reflex Thumbsticks Replacement, Remove the thumbsticks: step 5, image 2 of 3 Scuf Reflex Thumbsticks Replacement, Remove the thumbsticks: step 5, image 3 of 3
      • Pull the thumbsticks straight up and off of their joysticks to remove them.
      • To reinstall the thumbsticks, place them in their original position and push down until they lock in place.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
12 other people completed this guide.
Dominik Schnabelrauch
264,101 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,826 Guides authored
1 Guide Comment
Actually, the base of the thumbsticks is bigger and you can't pull it up. I really don't know if the new models are different.
I had to release the entire top cover.
Igor Minoru - Reply Share
Past 24 Hours: 8
Past 7 Days: 98
Past 30 Days: 438
All Time: 10,452
