Screwless Light Switch Wall Plate Replacement
    1. Screwless Light Switch Wall Plate Replacement, Light Switch Wall Plate: step 1, image 1 of 3 Screwless Light Switch Wall Plate Replacement, Light Switch Wall Plate: step 1, image 2 of 3 Screwless Light Switch Wall Plate Replacement, Light Switch Wall Plate: step 1, image 3 of 3
      • Caution: Before beginning this guide, turn the light switch off and turn off power to the switch at the circuit breaker.
      • They are usually labeled by the area of the house to which they belong.
      Ask FixBot
    2. Screwless Light Switch Wall Plate Replacement: step 2, image 1 of 3 Screwless Light Switch Wall Plate Replacement: step 2, image 2 of 3 Screwless Light Switch Wall Plate Replacement: step 2, image 3 of 3
      • Insert a prying tool into the two catches on the top of the light switch.
      • Slowly turn the prying tool or use it as a lever to push the outer plate away from the wall.
      Ask FixBot
    3. Screwless Light Switch Wall Plate Replacement: step 3, image 1 of 1
      • Remove the outer layer of the faceplate.
      Ask FixBot
    4. Screwless Light Switch Wall Plate Replacement: step 4, image 1 of 2 Screwless Light Switch Wall Plate Replacement: step 4, image 2 of 2
      • Remove the inner part of the faceplate by unscrewing the two screws on the top and the bottom.
      • Different faceplates use different screws. Use the screwdriver that works with your screws.
      Ask FixBot
    5. Screwless Light Switch Wall Plate Replacement: step 5, image 1 of 3 Screwless Light Switch Wall Plate Replacement: step 5, image 2 of 3 Screwless Light Switch Wall Plate Replacement: step 5, image 3 of 3
      • Unbox the new faceplate.
      • Just like Step 2, remove the outer layer of the new faceplate by inserting a prying tool in the catches on its top and bottom, pushing the two layers away from each other.
      Ask FixBot
    6. Screwless Light Switch Wall Plate Replacement: step 6, image 1 of 3 Screwless Light Switch Wall Plate Replacement: step 6, image 2 of 3 Screwless Light Switch Wall Plate Replacement: step 6, image 3 of 3
      • Hold the inner layer of the faceplate against the wall.
      • Align the holes in the plate with the existing holes on the light switch or power outlet.
      • Tighten the two screws on the top and bottom.
      Ask FixBot
    7. Screwless Light Switch Wall Plate Replacement: step 7, image 1 of 3 Screwless Light Switch Wall Plate Replacement: step 7, image 2 of 3 Screwless Light Switch Wall Plate Replacement: step 7, image 3 of 3
      • Attach the outer layer of the faceplate by putting it on top of the inner layer and slightly pushing it until you hear a click sound.
      Ask FixBot
You can follow this guide to replace a power outlet faceplate as the procedure is essentially the same.
7 other people completed this guide.
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 65
Past 30 Days: 302
All Time: 15,561
