This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Screen replacement HTC One A9s
      • Switch off the device
      Ask FixBot
      • Heat the top of the screen with a heat gun or hairdryer, then open it from above using a Jimmy tool. It is recommended to open the top of the screen first then work your way downward.
      Ask FixBot
      • Lift the screen
      • Use a screwdriver to disconnect the cover plate of the screen's connectiors
      Ask FixBot
      • Unplug the connections
      • Connect the new display and test it.
      Ask FixBot
      • If everything functions successfully, screw the cover plate back on.
      Ask FixBot
If water and dust protection is desired, a seal must be inserted when closing.
Special thanks to these translators:
de en
7%
Juan Garcia is helping us fix the world! Want to contribute?
Start translating ›
Marten
806 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 31
All Time: 262
