Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Spudger4.9
Introduction
Go to step 1 ↓This guide will walk through the process of removing the screen. This guide has a large number of steps due to the need to remove the motherboard from the device before the screen will be accessible. Double check the tools needed for this guide as soldering is necessary for this disassembly.
Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
Slide the opening tool to the right and slowly continue to separate the back cover from the device.
Remove the two ZIF connectors attached to the motherboard by flipping up the black tabs before pulling the ribbon cable away.
