Up to 20% off select tools
Screen Door Closer Replacement
Views: 13K
View statistics:
Past 24 Hours:
5
Past 7 Days:
37
Past 30 Days:
168
All Time:
12,774
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Does your screen door no longer close gently like it used to? Does it ever close behind you on
your ankle before you have both feet in the door? Not only can this be annoying but it can also
hurt! This a simple fast fix on how to replace your old screen door closer with a new one.
    1. Screen Door Closer Replacement, Door closer: step 1, image 1 of 1
      • Make sure the door is completely closed. push up from the bottom to remove the pin from the bracket that connects the barrel to the door frame and release the door closer barrel.
      • If the pin is under too much tension, open the door about an inch and slide the open clip (metal washer that keeps the screen door open) against the barrel and repeat step 1.
      Ask FixBot
    2. Screen Door Closer Replacement: step 2, image 1 of 1
      • After removing the pin, the closer barrel can be removed.
      Ask FixBot
    3. Screen Door Closer Replacement: step 3, image 1 of 1
      • Loosen the screws from the bracket on the screen door to remove the bracket.
      Ask FixBot
    4. Screen Door Closer Replacement: step 4, image 1 of 1
      • Loosen the screws from the door jamb bracket and remove.
      Ask FixBot
    5. Screen Door Closer Replacement: step 5, image 1 of 1
      • Attach the new bracket to the door jamb with provided screws.
      Ask FixBot
    6. Screen Door Closer Replacement: step 6, image 1 of 1
      • Slide the new clip (metal washer that was provided with the door closer) on the door closer barrel with the dented side facing inwards (as shown in photo).
      Ask FixBot
    7. Screen Door Closer Replacement: step 7, image 1 of 1
      • Insert the pin into the closer barrel and the jamb bracket.
      Ask FixBot
    8. Screen Door Closer Replacement: step 8, image 1 of 1
      • Install new bracket onto screen door. Keep screws slightly loose.
      Ask FixBot
    9. Screen Door Closer Replacement: step 9, image 1 of 1
      • Slip the other pin into the barrel and the bracket.
      Ask FixBot
    10. Screen Door Closer Replacement: step 10, image 1 of 1
      • Slide the bracket away from the barrel until there is no slack. Tighten screws on the bracket.
      Ask FixBot
    11. Screen Door Closer Replacement: step 11, image 1 of 1
      • Test the door and if there are any issues (i.e. door closing too fast or too slow). Make necessary adjustments to the tension screw.
      Ask FixBot
3 other people completed this guide.
Author
with
Shafaq Hasan
131 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 37
Past 30 Days: 168
All Time: 12,774
