Up to 20% off select tools
Scotch TL901 Heating Element Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
117
All Time:
1,938
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Parts
Tools
    1. Scotch TL901 Heating Element Replacement, Unscrewing top: step 1, image 1 of 1
      • Remove six Phillips screws from underneath the unit. Four screws are placed under the pads, one is open, and one may be covered by a sticker.
      Ask FixBot
    2. Scotch TL901 Heating Element Replacement, Removing cover: step 2, image 1 of 1
      • Open the unit by holding down the black bottom and pulling the silver top off.
      • Be careful of the wires connecting the power switch, as the power switch is screwed to the top case..
      Ask FixBot
      • Remove the beige-colored foam piece from the rollers. This is where the heating element is placed.
      • It may be hard to remove the element from the rollers because the element is tightly fastened in between the rollers.
      Ask FixBot
      • Pull off the cover to the fuse underneath. This may also be hard because the foam material is very grippy.
      Ask FixBot
      • You can either cut off the fuse from the wire or desolder the fuse. I chose to cut the fuse off, because I do not have tools needed to desolder.
      • Then just solder the new fuse onto the wires. You may want to make sure to have solder that can handle high temperatures, as this will go up to about 200 °C.
      Ask FixBot
2 other people completed this guide.
Author
with
JackMacWindows
155 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 117
All Time: 1,938
