Schwinn Tourist Inner Tube Replacement
Views: 5.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
78
All Time:
5,808
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will aid in removing a punctured or ruptured inner tube and replacing it with a new one.
    1. Schwinn Tourist Inner Tube Replacement, Front Inner Tube: step 1, image 1 of 1
      • Flip the bicycle upside down.
      • By flipping the bicycle upside down it will offer additional support by being able to stand up by itself.
      Ask FixBot
    2. Schwinn Tourist Inner Tube Replacement, Loosen The Brakes: step 2, image 1 of 1
      • Apply pressure to both sides of the brake arm with one hand and lift the metal brake cable from the brake caliper.
      • By releasing the brake cable from the brake caliper, it will loosen the brake pads by the tire.
      Ask FixBot
    3. Schwinn Tourist Inner Tube Replacement, Loosen The Quick Release Lever: step 3, image 1 of 2 Schwinn Tourist Inner Tube Replacement, Loosen The Quick Release Lever: step 3, image 2 of 2
      • Push the quick release lever outwards towards your body.
      • While holding the other end of the quick release lever, rotate the lever counter-clockwise until it is loose.
      Ask FixBot
    4. Schwinn Tourist Inner Tube Replacement, Remove Tire: step 4, image 1 of 1
      • Lift the tire to remove it from the bicycle.
      Ask FixBot
    5. Schwinn Tourist Inner Tube Replacement, Inserting The Tire Lever: step 5, image 1 of 1
      • Insert the flat end of the tire lever between the inside wall of the tire and the outside of the rim.
      • Attach the other end of the tire lever to the nearest spoke on the rim.
      Ask FixBot
    6. Schwinn Tourist Inner Tube Replacement, Insering Second Tire Lever: step 6, image 1 of 1
      • Insert a second tire lever next to the first lever to create leverage for releasing the tire from the rim.
      Ask FixBot
    7. Schwinn Tourist Inner Tube Replacement, Remove The Tire From The Rim: step 7, image 1 of 1
      • Leave the first lever in place. Slide the second lever against the outside edge of the rim until one side of the tire is off of the rim.
      Ask FixBot
    8. Schwinn Tourist Inner Tube Replacement, Remove The Tire From The Rim: step 8, image 1 of 1
      • Reattach the the first lever to the other side of the tire and repeat steps 4-7 to remove tire completely from rim.
      Ask FixBot
    9. Schwinn Tourist Inner Tube Replacement, Remove the Valve Stem: step 9, image 1 of 1
      • Push the valve stem upwards through the hole in the rim.
      Ask FixBot
    10. Schwinn Tourist Inner Tube Replacement, Finished: step 10, image 1 of 1
      • Once valve stem is pushed, pull the inner tube until it is completely removed from the rim.
      Ask FixBot
Quandre Mebane
149 Reputation
1 Guide authored
USF Tampa, Team 1-22, Donnelly Fall 2014 Member of USF Tampa, Team 1-22, Donnelly Fall 2014
USFT-DONNELLY-F14S1G22
1 Member
12 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 78
All Time: 5,808
