Satechi Aluminum Keyboard Disassembly
Views: 3.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
31
Past 30 Days:
155
All Time:
3,177
Comments: 6
4 comments on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 35 minutes
Difficulty: Difficult
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Introduction
Go to step 1 ↓
Overall the disassembly of the Satechi keyboard was very frustrating because of the heavy use of adhesive in the product. This product was definitely not designed to be easily repairable.
Tools
      • The power switch is located above the numpad on the vertical side of the keyboard
      Ask FixBot
    1. Satechi Aluminum Keyboard Disassembly, Removing the bottom plate: step 2, image 1 of 3 Satechi Aluminum Keyboard Disassembly, Removing the bottom plate: step 2, image 2 of 3 Satechi Aluminum Keyboard Disassembly, Removing the bottom plate: step 2, image 3 of 3
      • Remove the rubber feet (they are simply glued in place)
      • Use a heat source to soften the adhesive that holds down the bottom plate
      • Check the pictures to see where the adhesive is applied inside the device
      • Use a plastic pick or some other tool to cut through the adhesive
      • Remove the bottom plate
      Ask FixBot
    2. Satechi Aluminum Keyboard Disassembly, Removing the top cover: step 3, image 1 of 3 Satechi Aluminum Keyboard Disassembly, Removing the top cover: step 3, image 2 of 3 Satechi Aluminum Keyboard Disassembly, Removing the top cover: step 3, image 3 of 3
      • In order to get to the electronics inside we have to first remove the aluminium top cover
      • This is necessary because the plastic with the electronics underneath is clued to the top cover and is not removable without removing the clue
      • To remove the top cover first check out the images to see where to adhesive is applied on the cover
      • Use some heat source to soften the adhesive
      • Use a plastic pick or some other tool to cut through the adhesive (if the adhesive is really soft then simply applying pressure to the keycaps can help remove the cover)
      • Remove the cover
      Ask FixBot
    3. Satechi Aluminum Keyboard Disassembly, Remove plastic cover: step 4, image 1 of 3 Satechi Aluminum Keyboard Disassembly, Remove plastic cover: step 4, image 2 of 3 Satechi Aluminum Keyboard Disassembly, Remove plastic cover: step 4, image 3 of 3
      • Start by removing the twelve Phillips #00 screws marked in the picture
      • Now you should be able to lift the plastic cover
      Ask FixBot
    4. Satechi Aluminum Keyboard Disassembly, Battery close up: step 5, image 1 of 1
      • Insert wisdom here.
      Ask FixBot
Freeness2359
129 Reputation
1 Guide authored
2 Guide Comments
followed steps in order to fix the issue of slamming letter Y. Lots of adhesive confirmed for model ST-AMBK.
For all who seek - RTM if possible.
It is controller issue.
Myke S. - Reply Share
It should be illegal to make electronics this hard to disassemble.
robinbennich - Reply Share
Past 24 Hours: 5
Past 7 Days: 31
Past 30 Days: 155
All Time: 3,177
