Sapphire Nitro+ RX 6800 XT SE Fan Replacement
  1. Sapphire Nitro+ RX 6800 XT SE Fan Replacement, ARGB Fans: step 1, image 1 of 1
    • Unscrew the JIS000 screw securing the fan to the graphics card
    Ask FixBot
  2. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: step 2, image 1 of 1
    • Lift the fan from the top and pull away from you.
    Ask FixBot
  3. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: step 3, image 1 of 1
    • Clean any dust or residue present with a Q-tip damp with alcohol.
    Ask FixBot
  4. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: step 4, image 1 of 1
    • Flip the fan over and notice the pins on the fan and in the graphics card fan slot:
    • Fan Pins
    • Fan slot
    • Flip the fan back over keeping the same orientation and carfully insert the fan.
    • If inserted incorrectly the pins could bend or break!
    Ask FixBot
  5. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: step 5, image 1 of 1
    • Push the fan toward you to ensure that the pins are connected.
    Ask FixBot
  6. Sapphire Nitro+ RX 6800 XT SE Fan Replacement: step 6, image 1 of 1
    • Rescrew the JIS000 screw in the top of the fan.
    • Repeat steps 1 - 5 on the remaining fans if needed.
    • The center fan has a unique fan sicker to designate it as the middle.
    Ask FixBot
After assembly, the fans and RGB will work like new!
Weston Wood
183 Reputation
1 Guide authored
2 Guide Comments
What is the Screw used for this? I am having trouble finding a "3mm JIS 000" screw when I look it up. I accidentally dropped the screw somewhere in the pc when taking out the fan.
Ethan Callaway - Reply Share
Hello, I'm trying to find the screw too! Did you find it by any chance where to get replacement?
Waleed Almutairi - Reply Share
Past 24 Hours: 6
Past 7 Days: 26
Past 30 Days: 120
All Time: 2,724
