Sanyo-PM 8200 Motherboard Replacement
  1. Sanyo-PM 8200 Motherboard Replacement, Power Off Phone: step 1, image 1 of 1
    • Power down the phone by holding down the red "end" button.
    Ask FixBot
  2. Sanyo-PM 8200 Motherboard Replacement, Remove Old Battery: step 2, image 1 of 1
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
    Ask FixBot
  3. Sanyo-PM 8200 Motherboard Replacement, Back Casing: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Use a push pin or tweezers to remove the neoprene screw-cover located on the upper, left corner of the back casing.
    Ask FixBot
  4. Sanyo-PM 8200 Motherboard Replacement: step 4, image 1 of 1
    • Unscrew all four, 5mm Tri-Wing screws.
    Ask FixBot
  5. Sanyo-PM 8200 Motherboard Replacement: step 5, image 1 of 2 Sanyo-PM 8200 Motherboard Replacement: step 5, image 2 of 2
    • Pry the back casing off the device using a spudger. Work your way along the edges to completely separate the back casing from the device.
    • This step may require extra force. But too much force could break the back casing.
    • Remove the headphone jack cover when separating the back casing. The headphone jack is located on the opposite side of the antenna.
    Ask FixBot
  6. Sanyo-PM 8200 Motherboard Replacement, Lift the Motherboard: step 6, image 1 of 1
    • Gently lift up the motherboard. The keypad should now be exposed.
    Ask FixBot
  7. Sanyo-PM 8200 Motherboard Replacement, Disconnect the Flex Ribbon: step 7, image 1 of 1
    Buy
    • Using tweezers, pull on the silver flex ribbon to disconnect it from the motherboard.
    Ask FixBot
  8. Sanyo-PM 8200 Motherboard Replacement, Remove the Motherboard: step 8, image 1 of 1
    • Remove the motherboard from the back of the phone.
    Ask FixBot
Michaella
101 Reputation
1 Guide authored
USF Tampa, Team 1-6, Leahy Fall 2014 Member of USF Tampa, Team 1-6, Leahy Fall 2014
USFT-LEAHY-F14S1G6
6 Members
15 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 672
