Sanyo VPC-X1200 shutter assembly replacement
Views: 4.1K
View statistics:
Past 24 Hours:
Past 7 Days:
6
Past 30 Days:
43
All Time:
4,149
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Introduction
Go to step 1 ↓
This guide helps you to remove and replace the lens unit
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Sanyo VPC-X1200 shutter assembly replacement, Back Case: step 1, image 1 of 3 Sanyo VPC-X1200 shutter assembly replacement, Back Case: step 1, image 2 of 3 Sanyo VPC-X1200 shutter assembly replacement, Back Case: step 1, image 3 of 3
      • Remove the five case screws with a Phillips #00 Screwdriver.
      • Five 3.5mm Phillips Screws
      Ask FixBot
    2. Sanyo VPC-X1200 shutter assembly replacement: step 2, image 1 of 1
      • Gently lift up the back cover and set aside.
      Ask FixBot
    1. Sanyo VPC-X1200 shutter assembly replacement, LCD Screen: step 3, image 1 of 2 Sanyo VPC-X1200 shutter assembly replacement, LCD Screen: step 3, image 2 of 2
      • Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
      • Be careful not to rip out the ribbon connector.
      Ask FixBot
    2. Sanyo VPC-X1200 shutter assembly replacement: step 4, image 1 of 2 Sanyo VPC-X1200 shutter assembly replacement: step 4, image 2 of 2
      • To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger.
      • Gently lift ribbon out of the gate and set screen aside.
      Ask FixBot
    1. Sanyo VPC-X1200 shutter assembly replacement, Button Plate: step 5, image 1 of 2 Sanyo VPC-X1200 shutter assembly replacement, Button Plate: step 5, image 2 of 2
      • There are five screws of three different sizes which need removal.
      • One 4.5mm screw
      • Four 3.5mm screws, one on the button side
      • One 5.5mm screws
      Ask FixBot
    2. Sanyo VPC-X1200 shutter assembly replacement: step 6, image 1 of 2 Sanyo VPC-X1200 shutter assembly replacement: step 6, image 2 of 2
      • Slowly lift metal tray to the right.
      • Be careful not to bend the screw tabs or rip out the ribbon cable.
      • Remove ribbon cable by using the spudger to lift up the black ribbon gate to release the ribbon
      Ask FixBot
    1. Sanyo VPC-X1200 shutter assembly replacement, Lens Unit: step 7, image 1 of 1
      • Disconnect the two ribbon cables from the lens unit by using the spudger to lift the ribbon gates.
      • One gate is black and another is white.
      Ask FixBot
    2. Sanyo VPC-X1200 shutter assembly replacement: step 8, image 1 of 2 Sanyo VPC-X1200 shutter assembly replacement: step 8, image 2 of 2
      • Remove the three silver screws.
      • Three 5.5mm screws
      Ask FixBot
    3. Sanyo VPC-X1200 shutter assembly replacement: step 9, image 1 of 1
      • Lift the lens unit free of the camera. A spudger can be used to separate the lens unit if necessary.
      Ask FixBot
Anthony Giardina
35 Reputation
7 Guides authored
Cal Poly, Team 7-10, Maness Spring 2010 Member of Cal Poly, Team 7-10, Maness Spring 2010
CPSU-MANESS-S10S7G10
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 43
All Time: 4,149
