Sanyo VPC-X1200 flash replacement
Views: 2.7K
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
50
All Time:
2,725
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Introduction
Go to step 1 ↓
This guide will help you to remove and replace the flash lens
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Sanyo VPC-X1200 flash replacement, Back Case: step 1, image 1 of 3 Sanyo VPC-X1200 flash replacement, Back Case: step 1, image 2 of 3 Sanyo VPC-X1200 flash replacement, Back Case: step 1, image 3 of 3
      • Remove the five case screws with a Phillips #00 Screwdriver.
      • Five 3.5mm Phillips Screws
      Ask FixBot
    2. Sanyo VPC-X1200 flash replacement: step 2, image 1 of 1
      • Gently lift up the back cover and set aside.
      Ask FixBot
    1. Sanyo VPC-X1200 flash replacement, LCD Screen: step 3, image 1 of 2 Sanyo VPC-X1200 flash replacement, LCD Screen: step 3, image 2 of 2
      • Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
      • Be careful not to rip out the ribbon connector.
      Ask FixBot
    2. Sanyo VPC-X1200 flash replacement: step 4, image 1 of 2 Sanyo VPC-X1200 flash replacement: step 4, image 2 of 2
      • To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger.
      • Gently lift ribbon out of the gate and set screen aside.
      Ask FixBot
    1. Sanyo VPC-X1200 flash replacement, Button Plate: step 5, image 1 of 2 Sanyo VPC-X1200 flash replacement, Button Plate: step 5, image 2 of 2
      • There are five screws of three different sizes which need removal.
      • One 4.5mm screw
      • Four 3.5mm screws, one on the button side
      • One 5.5mm screws
      Ask FixBot
    2. Sanyo VPC-X1200 flash replacement: step 6, image 1 of 2 Sanyo VPC-X1200 flash replacement: step 6, image 2 of 2
      • Slowly lift metal tray to the right.
      • Be careful not to bend the screw tabs or rip out the ribbon cable.
      • Remove ribbon cable by using the spudger to lift up the black ribbon gate to release the ribbon
      Ask FixBot
    1. Sanyo VPC-X1200 flash replacement, Lens Unit: step 7, image 1 of 1
      • Disconnect the two ribbon cables from the lens unit by using the spudger to lift the ribbon gates.
      • One gate is black and another is white.
      Ask FixBot
    2. Sanyo VPC-X1200 flash replacement: step 8, image 1 of 2 Sanyo VPC-X1200 flash replacement: step 8, image 2 of 2
      • Remove the three silver screws.
      • Three 5.5mm screws
      Ask FixBot
    3. Sanyo VPC-X1200 flash replacement: step 9, image 1 of 1
      • Lift the lens unit free of the camera. A spudger can be used to separate the lens unit if necessary.
      Ask FixBot
    1. Sanyo VPC-X1200 flash replacement, Flash Lens: step 10, image 1 of 3 Sanyo VPC-X1200 flash replacement, Flash Lens: step 10, image 2 of 3 Sanyo VPC-X1200 flash replacement, Flash Lens: step 10, image 3 of 3
      • Remove 4 screws attached to the exterior silver bezel.
      • Four 3.5mm screws
      Ask FixBot
    2. Sanyo VPC-X1200 flash replacement: step 11, image 1 of 1
      • Remove round silver bezel from the front of the camera.
      Ask FixBot
    3. Sanyo VPC-X1200 flash replacement: step 12, image 1 of 1
      • Remove the two screws on the bottom of the front cover.
      Ask FixBot
    4. Sanyo VPC-X1200 flash replacement: step 13, image 1 of 1
      • Remove tripod mount.
      Ask FixBot
    5. Sanyo VPC-X1200 flash replacement: step 14, image 1 of 1
      • Carefully lift off the front cover plate of the camera.
      Ask FixBot
    6. Sanyo VPC-X1200 flash replacement: step 15, image 1 of 1
      • Remove the flash lens using the spudger or a finger.
      • It will be attached by a piece of tape, peel the lens off of that piece of tape without removing the tape.
      Ask FixBot
Anthony Giardina
35 Reputation
7 Guides authored
Cal Poly, Team 7-10, Maness Spring 2010 Member of Cal Poly, Team 7-10, Maness Spring 2010
CPSU-MANESS-S10S7G10
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 50
All Time: 2,725
