Sanyo VPC-X1200 LCD Screen Replacement
  1. Sanyo VPC-X1200 LCD Screen Replacement, Back Case: step 1, image 1 of 3 Sanyo VPC-X1200 LCD Screen Replacement, Back Case: step 1, image 2 of 3 Sanyo VPC-X1200 LCD Screen Replacement, Back Case: step 1, image 3 of 3
    • Remove the five case screws with a Phillips #00 Screwdriver.
    • Five 3.5mm Phillips Screws
    Ask FixBot
  2. Sanyo VPC-X1200 LCD Screen Replacement: step 2, image 1 of 1
    • Gently lift up the back cover and set aside.
    Ask FixBot
  3. Sanyo VPC-X1200 LCD Screen Replacement, LCD Screen: step 3, image 1 of 2 Sanyo VPC-X1200 LCD Screen Replacement, LCD Screen: step 3, image 2 of 2
    • Gently lift up on the left side of the LCD and slowly pull it to the left side of the camera but do not remove entirely, there is a ribbon connector.
    • Be careful not to rip out the ribbon connector.
    Ask FixBot
  4. Sanyo VPC-X1200 LCD Screen Replacement: step 4, image 1 of 2 Sanyo VPC-X1200 LCD Screen Replacement: step 4, image 2 of 2
    • To clear the ribbon connection underneath the screen, lift up the black ribbon gate with the spudger.
    • Gently lift ribbon out of the gate and set screen aside.
    Ask FixBot
Anthony Giardina
35 Reputation
7 Guides authored
Cal Poly, Team 7-10, Maness Spring 2010 Member of Cal Poly, Team 7-10, Maness Spring 2010
CPSU-MANESS-S10S7G10
4 Members
15 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 36
All Time: 5,534
