Sanyo VPC-T850 Photo Array Device Replacement
    1. Sanyo VPC-T850 Photo Array Device Replacement, Battery: step 1, image 1 of 1
      • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
      Ask FixBot
    2. Sanyo VPC-T850 Photo Array Device Replacement: step 2, image 1 of 1
      • Locate the hatch found on the bottom of the camera.
      • Open the hatch by gripping the small notch and sliding it outwards.
      Ask FixBot
    3. Sanyo VPC-T850 Photo Array Device Replacement: step 3, image 1 of 1
      • Push the small, plastic arm out of the way to free the battery.
      • The battery is spring loaded and will pop out slightly when the arm is moved.
      Ask FixBot
    4. Sanyo VPC-T850 Photo Array Device Replacement: step 4, image 1 of 1
      • Pull the battery out of the camera and close the hatch.
      • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
      Ask FixBot
    1. Sanyo VPC-T850 Photo Array Device Replacement, Outer Casing: step 5, image 1 of 3 Sanyo VPC-T850 Photo Array Device Replacement, Outer Casing: step 5, image 2 of 3 Sanyo VPC-T850 Photo Array Device Replacement, Outer Casing: step 5, image 3 of 3
      • Using your Phillips #000 Screwdriver, remove the eight screws located around the sides and bottom of the camera.
      • Be sure to keep track of the side each screw comes from, as they come in different lengths.
      Ask FixBot
    2. Sanyo VPC-T850 Photo Array Device Replacement: step 6, image 1 of 2 Sanyo VPC-T850 Photo Array Device Replacement: step 6, image 2 of 2
      • Orient the camera so the display is facing up.
      • Gently pull off the rear panel surrounding the display.
      • There are still three green wires connecting the panel to the rest of the camera.
      • Use your prying tool if you have difficulties removing the panel by hand.
      Ask FixBot
    3. Sanyo VPC-T850 Photo Array Device Replacement: step 7, image 1 of 1
      • Remove the eight black screws connecting the keypad circuit board to the rear panel.
      Ask FixBot
    4. Sanyo VPC-T850 Photo Array Device Replacement: step 8, image 1 of 2 Sanyo VPC-T850 Photo Array Device Replacement: step 8, image 2 of 2
      • With a plastic opening tool, gently remove the chrome framing on the left and right sides of the camera.
      Ask FixBot
    5. Sanyo VPC-T850 Photo Array Device Replacement: step 9, image 1 of 1
      • Flip the camera over so the lens is facing up.
      • Gently lift up the front panel to remove it from the rest of the camera.
      • Use your plastic opening tool if you have difficulties removing the panel by hand.
      Ask FixBot
    1. Sanyo VPC-T850 Photo Array Device Replacement, LCD Display: step 10, image 1 of 1
      • Flip the device over to where the display is located.
      • Using your plastic opening tool, lift the display out of its metal housing.
      Ask FixBot
    2. Sanyo VPC-T850 Photo Array Device Replacement: step 11, image 1 of 1
      • Locate the orange ribbon connecting the display to the camera.
      • Using your plastic opening tool, gently lift the black bar holding the orange ribbon to the camera.
      Ask FixBot
    3. Sanyo VPC-T850 Photo Array Device Replacement: step 12, image 1 of 1
      • With two fingers held firmly on the display, gently pull the orange ribbon out of the camera.
      • Pull slowly to avoid severing the orange ribbon from the display.
      Ask FixBot
    1. Sanyo VPC-T850 Photo Array Device Replacement, Photo Array Device: step 13, image 1 of 1
      • Remove the two screws holding the photo array.
      Ask FixBot
    2. Sanyo VPC-T850 Photo Array Device Replacement: step 14, image 1 of 3 Sanyo VPC-T850 Photo Array Device Replacement: step 14, image 2 of 3 Sanyo VPC-T850 Photo Array Device Replacement: step 14, image 3 of 3
      • Remove the foam from the top of the wire connector.
      • Gently remove the plastic connector in the same way as the previous connector of the same type.
      • Lift the connector from the side with the ribbon cable in it.
      • Using the spudger, gently push from the right side.
      Ask FixBot
Jonathan Yau
26 Reputation
4 Guides authored
Cal Poly, Team 27-95, Amido Spring 2010 Member of Cal Poly, Team 27-95, Amido Spring 2010
CPSU-AMIDO-S10S27G95
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 38
All Time: 2,604
