Introduction
If your camera is having trouble turning on, it is likely due to an issue with the battery. This guide will go through the steps needed to replace the battery of a Sanyo VPC-T850.
Warning: Always turn off the power before handling battery.
Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
