Sanyo Katana Speaker Replacement
  1. Sanyo Katana Speaker Replacement, Battery: step 1, image 1 of 3 Sanyo Katana Speaker Replacement, Battery: step 1, image 2 of 3 Sanyo Katana Speaker Replacement, Battery: step 1, image 3 of 3
    • Place thumb on the tab located at the back of the phone and slide button towards your hand and away from phone.
    • While holding down the button, pull cover off with other hand.
    Ask FixBot
  2. Sanyo Katana Speaker Replacement: step 2, image 1 of 3 Sanyo Katana Speaker Replacement: step 2, image 2 of 3 Sanyo Katana Speaker Replacement: step 2, image 3 of 3
    • Use fingers to grip the battery and remove it from the phone.
    Ask FixBot
  3. Sanyo Katana Speaker Replacement, Back Casing: step 3, image 1 of 1
    • Using a spudger, remove the four rubber coverings on the lower back plate.
    Ask FixBot
  4. Sanyo Katana Speaker Replacement: step 4, image 1 of 3 Sanyo Katana Speaker Replacement: step 4, image 2 of 3 Sanyo Katana Speaker Replacement: step 4, image 3 of 3
    • Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate.
    Ask FixBot
  5. Sanyo Katana Speaker Replacement: step 5, image 1 of 3 Sanyo Katana Speaker Replacement: step 5, image 2 of 3 Sanyo Katana Speaker Replacement: step 5, image 3 of 3
    • Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate.
    Ask FixBot
  6. Sanyo Katana Speaker Replacement, Speaker: step 6, image 1 of 2 Sanyo Katana Speaker Replacement, Speaker: step 6, image 2 of 2
    • Gently tap the lower back casing on a hard surface to remove the speaker.
    Ask FixBot
Preston
216 Reputation
5 Guides authored
Clemson, Team 12-1, Benson Spring 2013 Member of Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Members
20 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 73
All Time: 604
