Sanyo Katana Screen Replacement
    1. Sanyo Katana Screen Replacement, Screen Protector: step 1, image 1 of 2 Sanyo Katana Screen Replacement, Screen Protector: step 1, image 2 of 2
      • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
      Ask FixBot
    2. Sanyo Katana Screen Replacement: step 2, image 1 of 2 Sanyo Katana Screen Replacement: step 2, image 2 of 2
      • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
      Ask FixBot
    3. Sanyo Katana Screen Replacement: step 3, image 1 of 2 Sanyo Katana Screen Replacement: step 3, image 2 of 2
      • Carefully pry the screen protector off the phone using the flat end of the spudger.
      • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
      • Once free from the adhesive, pull the screen protector away from the phone.
      Ask FixBot
    1. Sanyo Katana Screen Replacement, Front Case: step 4, image 1 of 3 Sanyo Katana Screen Replacement, Front Case: step 4, image 2 of 3 Sanyo Katana Screen Replacement, Front Case: step 4, image 3 of 3
      • Use the spudger to pry off the front case from the left and right sides of the device.
      • Once it has popped off, pull the casing apart with fingers.
      Ask FixBot
    1. Sanyo Katana Screen Replacement, Screen: step 5, image 1 of 2 Sanyo Katana Screen Replacement, Screen: step 5, image 2 of 2
      • Using a Tri-wing Y0 screwdriver, remove the 4.4mm screw.
      • Use fingers to remove the strip from the device.
      Ask FixBot
    2. Sanyo Katana Screen Replacement: step 6, image 1 of 3 Sanyo Katana Screen Replacement: step 6, image 2 of 3 Sanyo Katana Screen Replacement: step 6, image 3 of 3
      • Use a spudger to detach all of the connections to the motherboard in the back of the phone by the screen.
      Ask FixBot
    3. Sanyo Katana Screen Replacement: step 7, image 1 of 2 Sanyo Katana Screen Replacement: step 7, image 2 of 2
      • Use the flat edge of the spudger to detach the screen from the phone casing.
      • Pull the screen up and away from the case.
      Ask FixBot
Aliceann
49 Reputation
1 Guide authored
Clemson, Team 12-1, Benson Spring 2013 Member of Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 1,090
