Sanyo Katana Screen Protector Replacement
    1. Sanyo Katana Screen Protector Replacement, Screen Protector: step 1, image 1 of 2 Sanyo Katana Screen Protector Replacement, Screen Protector: step 1, image 2 of 2
      • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
      Ask FixBot
    2. Sanyo Katana Screen Protector Replacement: step 2, image 1 of 2 Sanyo Katana Screen Protector Replacement: step 2, image 2 of 2
      • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
      Ask FixBot
    3. Sanyo Katana Screen Protector Replacement: step 3, image 1 of 2 Sanyo Katana Screen Protector Replacement: step 3, image 2 of 2
      • Carefully pry the screen protector off the phone using the flat end of the spudger.
      • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
      • Once free from the adhesive, pull the screen protector away from the phone.
      Ask FixBot
StephenYH
20 Reputation
3 Guides authored
Clemson, Team 12-1, Benson Spring 2013 Member of Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 30
All Time: 639
