Sanyo Katana Motherboard Replacement
    1. Sanyo Katana Motherboard Replacement, Battery: step 1, image 1 of 3 Sanyo Katana Motherboard Replacement, Battery: step 1, image 2 of 3 Sanyo Katana Motherboard Replacement, Battery: step 1, image 3 of 3
      • Place thumb on the tab located at the back of the phone and slide button towards your hand and away from phone.
      • While holding down the button, pull cover off with other hand.
      Ask FixBot
    2. Sanyo Katana Motherboard Replacement: step 2, image 1 of 3 Sanyo Katana Motherboard Replacement: step 2, image 2 of 3 Sanyo Katana Motherboard Replacement: step 2, image 3 of 3
      • Use fingers to grip the battery and remove it from the phone.
      Ask FixBot
    1. Sanyo Katana Motherboard Replacement, Back Casing: step 3, image 1 of 1
      • Using a spudger, remove the four rubber coverings on the lower back plate.
      Ask FixBot
    2. Sanyo Katana Motherboard Replacement: step 4, image 1 of 3 Sanyo Katana Motherboard Replacement: step 4, image 2 of 3 Sanyo Katana Motherboard Replacement: step 4, image 3 of 3
      • Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate.
      Ask FixBot
    3. Sanyo Katana Motherboard Replacement: step 5, image 1 of 3 Sanyo Katana Motherboard Replacement: step 5, image 2 of 3 Sanyo Katana Motherboard Replacement: step 5, image 3 of 3
      • Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate.
      Ask FixBot
    1. Sanyo Katana Motherboard Replacement, Motherboard: step 6, image 1 of 2 Sanyo Katana Motherboard Replacement, Motherboard: step 6, image 2 of 2
      • Unscrew the 4.4mm screws at the top of the phone with the Tri-wing Y0 Screwdriver.
      Ask FixBot
    2. Sanyo Katana Motherboard Replacement: step 7, image 1 of 3 Sanyo Katana Motherboard Replacement: step 7, image 2 of 3 Sanyo Katana Motherboard Replacement: step 7, image 3 of 3
      • For the following steps, the phone is shown closed to make manipulating the parts easier.
      • Using a spudger, remove the thin aluminum plate to access the upper motherboard.
      • This will most likely be difficult to pry off and will take a considerable amount of force. Stay clear of the piece to avoid injury when it comes free of the device.
      Ask FixBot
    3. Sanyo Katana Motherboard Replacement: step 8, image 1 of 1
      • Use the flat end of the spudger to remove two ribbon cables from the back of the motherboard.
      Ask FixBot
    4. Sanyo Katana Motherboard Replacement: step 9, image 1 of 3 Sanyo Katana Motherboard Replacement: step 9, image 2 of 3 Sanyo Katana Motherboard Replacement: step 9, image 3 of 3
      • Open the phone and firmly hold the phone casing with one hand and push the motherboard out of the case with the other by pushing on the keys.
      • Once the keys are free from the casing, close the phone and pull the motherboard from the back of the phone the remainder of the way with your fingers.
      Ask FixBot
StephenYH
20 Reputation
3 Guides authored
Clemson, Team 12-1, Benson Spring 2013 Member of Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Members
110 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 22
All Time: 841
