Sanyo Katana Back Casing Replacement
    1. Sanyo Katana Back Casing Replacement, Battery: step 1, image 1 of 3 Sanyo Katana Back Casing Replacement, Battery: step 1, image 2 of 3 Sanyo Katana Back Casing Replacement, Battery: step 1, image 3 of 3
      • Place thumb on the tab located at the back of the phone and slide button towards your hand and away from phone.
      • While holding down the button, pull cover off with other hand.
      Ask FixBot
    2. Sanyo Katana Back Casing Replacement: step 2, image 1 of 3 Sanyo Katana Back Casing Replacement: step 2, image 2 of 3 Sanyo Katana Back Casing Replacement: step 2, image 3 of 3
      • Use fingers to grip the battery and remove it from the phone.
      Ask FixBot
    1. Sanyo Katana Back Casing Replacement, Back Casing: step 3, image 1 of 1
      • Using a spudger, remove the four rubber coverings on the lower back plate.
      Ask FixBot
    2. Sanyo Katana Back Casing Replacement: step 4, image 1 of 3 Sanyo Katana Back Casing Replacement: step 4, image 2 of 3 Sanyo Katana Back Casing Replacement: step 4, image 3 of 3
      • Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate.
      Ask FixBot
    3. Sanyo Katana Back Casing Replacement: step 5, image 1 of 3 Sanyo Katana Back Casing Replacement: step 5, image 2 of 3 Sanyo Katana Back Casing Replacement: step 5, image 3 of 3
      • Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate.
      Ask FixBot
2 other people completed this guide.
Preston
216 Reputation
5 Guides authored
Clemson, Team 12-1, Benson Spring 2013 Member of Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 28
All Time: 951
