Up to 20% off select tools
Sansa e260R Scroll Wheel Replacement
Views: 4.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
96
All Time:
4,227
Comments: 1
1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Sansa e260R Scroll Wheel Replacement, Rear Case: step 1, image 1 of 1
      • Before disassembling the device, make sure it is powered off.
      • Remove the four 1.5mm screws on the back of the device.
      Ask FixBot
    2. Sansa e260R Scroll Wheel Replacement: step 2, image 1 of 1
      • Using a plastic opening tool, lift the metal backing from the front of the device.
      Ask FixBot
    3. Sansa e260R Scroll Wheel Replacement: step 3, image 1 of 1
      • Pull the rear panel off of the Sansa e260R.
      Ask FixBot
    1. Sansa e260R Scroll Wheel Replacement, Battery: step 4, image 1 of 1
      • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
      Ask FixBot
    1. Sansa e260R Scroll Wheel Replacement, Front Panel: step 5, image 1 of 1
      • Remove the four 1.5mm screws on the inner casing of the device.
      • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
      Ask FixBot
    2. Sansa e260R Scroll Wheel Replacement: step 6, image 1 of 1
      • Flip the device so that the front is facing you.
      • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
      Ask FixBot
    3. Sansa e260R Scroll Wheel Replacement: step 7, image 1 of 2 Sansa e260R Scroll Wheel Replacement: step 7, image 2 of 2
      • Pull the front cover away from the rest of the device.
      Ask FixBot
    1. Sansa e260R Scroll Wheel Replacement, Scroll Wheel: step 8, image 1 of 2 Sansa e260R Scroll Wheel Replacement, Scroll Wheel: step 8, image 2 of 2
      • Gently pry the bottom of the black button to remove it from the device.
      Ask FixBot
    2. Sansa e260R Scroll Wheel Replacement: step 9, image 1 of 2 Sansa e260R Scroll Wheel Replacement: step 9, image 2 of 2
      • There are 4 small metal hooks under the white scrolling mechanism.
      • To remove the white scrolling mechanism, remove two of the bottom hooks using a spudger.
      Ask FixBot
    3. Sansa e260R Scroll Wheel Replacement: step 10, image 1 of 1
      • Clean the area around the button to remove any dirt or other outside material that would prevent the scroll wheel from moving freely.
      Ask FixBot
6 other people completed this guide.
Author
with
JenniferW
194 Reputation
2 Guides authored
Cal Poly, Team 8-15, Maness Winter 2012 Member of Cal Poly, Team 8-15, Maness Winter 2012
CPSU-MANESS-W12S8G15
5 Members
60 Guides authored
1 Guide Comment
Thanks very much for this guide. I used it to expose and clean my Sansa scroll wheel which is now functioning much better.
Lloyd Merriam - Reply Share
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 96
All Time: 4,227
