Up to 20% off select tools
Sansa e260R Front Panel Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
107
All Time:
2,637
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
    1. Sansa e260R Front Panel Replacement, Rear Case: step 1, image 1 of 1
      • Before disassembling the device, make sure it is powered off.
      • Remove the four 1.5mm screws on the back of the device.
      Ask FixBot
    2. Sansa e260R Front Panel Replacement: step 2, image 1 of 1
      • Using a plastic opening tool, lift the metal backing from the front of the device.
      Ask FixBot
    3. Sansa e260R Front Panel Replacement: step 3, image 1 of 1
      • Pull the rear panel off of the Sansa e260R.
      Ask FixBot
    1. Sansa e260R Front Panel Replacement, Battery: step 4, image 1 of 1
      • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
      Ask FixBot
    1. Sansa e260R Front Panel Replacement, Front Panel: step 5, image 1 of 1
      • Remove the four 1.5mm screws on the inner casing of the device.
      • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
      Ask FixBot
    2. Sansa e260R Front Panel Replacement: step 6, image 1 of 1
      • Flip the device so that the front is facing you.
      • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
      Ask FixBot
    3. Sansa e260R Front Panel Replacement: step 7, image 1 of 2 Sansa e260R Front Panel Replacement: step 7, image 2 of 2
      • Pull the front cover away from the rest of the device.
      Ask FixBot
Author
with
Casey Smith
111 Reputation
3 Guides authored
Cal Poly, Team 8-15, Maness Winter 2012 Member of Cal Poly, Team 8-15, Maness Winter 2012
CPSU-MANESS-W12S8G15
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 107
All Time: 2,637
