Sansa e260R Battery Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
99
All Time:
3,283
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Parts
Tools
    1. Sansa e260R Battery Replacement, Rear Case: step 1, image 1 of 1
      • Before disassembling the device, make sure it is powered off.
      • Remove the four 1.5mm screws on the back of the device.
      Ask FixBot
    2. Sansa e260R Battery Replacement: step 2, image 1 of 1
      • Using a plastic opening tool, lift the metal backing from the front of the device.
      Ask FixBot
    3. Sansa e260R Battery Replacement: step 3, image 1 of 1
      • Pull the rear panel off of the Sansa e260R.
      Ask FixBot
    1. Sansa e260R Battery Replacement, Battery: step 4, image 1 of 1
      • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
      Ask FixBot
Casey Smith
111 Reputation
3 Guides authored
Cal Poly, Team 8-15, Maness Winter 2012 Member of Cal Poly, Team 8-15, Maness Winter 2012
CPSU-MANESS-W12S8G15
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 99
All Time: 3,283
