Sanitaire SC684 front wheel replacement
Views: 1.8K
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
66
All Time:
1,755
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
There are many small things we interact with that make our lives easier that we often don’t think about, such as the wheels of a vacuum, which can deteriorate over time and need replacing. This guide is for Sanitaire SC684 owners who have found their vacuums front wheels in need of replacing.
Tools
    1. Sanitaire SC684 front wheel replacement, Front Wheels: step 1, image 1 of 1
      • Be sure to unplug the vacuum before disassembling it to prevent electric shock.
      • Lay the vacuum on its side.
      • Using a Phillips #1 screwdriver, unscrew the screws located behind the front wheels on the underside of the vacuum.
      Ask FixBot
    2. Sanitaire SC684 front wheel replacement: step 2, image 1 of 2 Sanitaire SC684 front wheel replacement: step 2, image 2 of 2
      • Stand the vacuum upright, unscrew the single screw located on the center dial using a Torx T20 screwdriver and remove the dial form the vacuum body.
      Ask FixBot
    3. Sanitaire SC684 front wheel replacement: step 3, image 1 of 1
      • Lift the top cover off of the vacuum.
      Ask FixBot
    4. Sanitaire SC684 front wheel replacement: step 4, image 1 of 1
      • Identify the two gray metal plates at the front of the vacuum.
      • Using the T20 Torx screwdriver, remove the four screws on the smaller gray plate holding the larger gray metal plates.
      Ask FixBot
    5. Sanitaire SC684 front wheel replacement: step 5, image 1 of 2 Sanitaire SC684 front wheel replacement: step 5, image 2 of 2
      • Remove the small metal plate with the black bolt in the center and the larger gray plate from both sides.
      Ask FixBot
    6. Sanitaire SC684 front wheel replacement: step 6, image 1 of 2 Sanitaire SC684 front wheel replacement: step 6, image 2 of 2
      • Pull out the silver bar that holds the two wheels to the vacuum body and detach the small spring from the vacuum body.
      Ask FixBot
    7. Sanitaire SC684 front wheel replacement: step 7, image 1 of 2 Sanitaire SC684 front wheel replacement: step 7, image 2 of 2
      • Remove the wheel from the side with the spring by pulling it off the axel and slide off the spring, as it will be needed for the replacement front wheels.
      Ask FixBot
Caycie Pascual
1 Reputation
4 Guides authored
Cal Poly, Team 16-58, Forte Fall 2012 Member of Cal Poly, Team 16-58, Forte Fall 2012
CPSU-FORTE-F12S16G58
5 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 66
All Time: 1,755
