Introduction
This guide will explain how to replace the battery of a Sandisk Sansa C250 digital player. The battery in the device will need to be replaced if it cannot charge or if battery life capacity is reduced after multiple recharges. Soldering is a special skill required. Pay attention to cautions or notes in the steps.
To remove the back cover, slide the back cover toward the top of the device with your thumb.
Using a Phillips head screwdriver, remove the two black .265" screws at the base of the device.
Using a Phillips head screwdriver, remove the single 0.327" silver screw on the back of the device. The screw should be exposed from when you removed the rear case cover.
Using a plastic pry tool, lift the battery up and away from the board and note its orientation.
