SanDisk Sansa C250 Battery Replacement
  1. SanDisk Sansa C250 Battery Replacement, Battery Cover: step 1, image 1 of 2 SanDisk Sansa C250 Battery Replacement, Battery Cover: step 1, image 2 of 2
    • To remove the back cover, slide the back cover toward the top of the device with your thumb.
    Ask FixBot
  2. SanDisk Sansa C250 Battery Replacement, Battery: step 2, image 1 of 1
    • Wedge the plastic pry tool under the edge of the battery.
    • An iFixIt opening tool can be used in place of a plastic pry tool in this step and the following steps.
    Ask FixBot
  3. SanDisk Sansa C250 Battery Replacement: step 3, image 1 of 2 SanDisk Sansa C250 Battery Replacement: step 3, image 2 of 2
    • With the plastic pry tool, gently lift up. The battery should lift up and out.
    Ask FixBot
Nicolas Coffey
58 Reputation
4 Guides authored
Cal Poly, Team 3-30, Amido Winter 2012 Member of Cal Poly, Team 3-30, Amido Winter 2012
CPSU-AMIDO-W12S3G30
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 55
All Time: 3,198
