Tools
Spudger4.9
Introduction
Go to step 1 ↓Use this guide to replace a malfunctioning or defective sensor array on your Samsung Galaxy Watch Active.
Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3Â seconds. You should feel a short vibration.
When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
Use a Tri-point Y00 screwdriver to remove the four 4Â mm-long screws on the back of the watch.
Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
Push the tip of the opening tool into the gap to separate the back cover from the housing.
Carefully lift the back cover approximately 2Â cm to access the sensor array connector near the two buttons.
Use a spudger to disconnect the sensor array from the motherboard.
Use an opening pick and slide it underneath the sensor array which is slightly glued in place.
Carefully twist the opening pick to separate the sensor array from the back cover.
