Up to 20% off select tools
Samsung Watch Active Screen Replacement
Views: 7.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
32
Past 30 Days:
161
All Time:
7,279
Comments: 16
13 comments on steps, 3 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 35 minutes - 1 hour
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a cracked or broken screen on your Samsung Galaxy Watch Active.
Note: Some replacement screens come pre-installed in a new frame. That's a different procedure from what's shown in this guide. If you're replacing the screen and frame together, follow this guide instead.
You’ll need replacement adhesive to reassemble your device.
    1. Samsung Watch Active Screen Replacement, Turn off the watch: step 1, image 1 of 2 Samsung Watch Active Screen Replacement, Turn off the watch: step 1, image 2 of 2
      • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
      • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
      Ask FixBot
    2. Samsung Watch Active Screen Replacement, Remove the rear screws: step 2, image 1 of 1
      • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
      Ask FixBot
    3. Samsung Watch Active Screen Replacement, Separate the back cover from the housing: step 3, image 1 of 3 Samsung Watch Active Screen Replacement, Separate the back cover from the housing: step 3, image 2 of 3 Samsung Watch Active Screen Replacement, Separate the back cover from the housing: step 3, image 3 of 3
      • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
      • Push the tip of the opening tool into the gap to separate the back cover from the housing.
      • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
      Ask FixBot
    4. Samsung Watch Active Screen Replacement, Disconnect the sensor array: step 4, image 1 of 2 Samsung Watch Active Screen Replacement, Disconnect the sensor array: step 4, image 2 of 2
      • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
      • Use a spudger to disconnect the sensor array from the motherboard.
      Ask FixBot
    5. Samsung Watch Active Screen Replacement, Remove the back cover: step 5, image 1 of 1
      • Remove the back cover.
      Ask FixBot
    1. Samsung Watch Active Screen Replacement, Disconnect the display and the mic array: step 6, image 1 of 3 Samsung Watch Active Screen Replacement, Disconnect the display and the mic array: step 6, image 2 of 3 Samsung Watch Active Screen Replacement, Disconnect the display and the mic array: step 6, image 3 of 3
      • Use a spudger to disconnect the display assembly and the microphone and pressure sensor array.
      Ask FixBot
    2. Samsung Watch Active Screen Replacement, Undo the mic tape: step 7, image 1 of 3 Samsung Watch Active Screen Replacement, Undo the mic tape: step 7, image 2 of 3 Samsung Watch Active Screen Replacement, Undo the mic tape: step 7, image 3 of 3
      • Use an opening pick to peel back the thin tape belonging to the microphone array.
      • When re-assembling make sure this tape properly sticks to the motherboard by pressing it down with the flat end of a spudger.
      Ask FixBot
    3. Samsung Watch Active Screen Replacement, Lift the core assembly: step 8, image 1 of 2 Samsung Watch Active Screen Replacement, Lift the core assembly: step 8, image 2 of 2
      • Insert an opening pick at the bottom right between the motherboard and the frame to lift up the core assembly.
      Ask FixBot
    4. Samsung Watch Active Screen Replacement, Remove the core assembly: step 9, image 1 of 3 Samsung Watch Active Screen Replacement, Remove the core assembly: step 9, image 2 of 3 Samsung Watch Active Screen Replacement, Remove the core assembly: step 9, image 3 of 3
      • Lift out and remove the core assembly.
      Ask FixBot
    1. Samsung Watch Active Screen Replacement, Loosen the mic: step 10, image 1 of 2 Samsung Watch Active Screen Replacement, Loosen the mic: step 10, image 2 of 2
      • Use a spudger to loosen the microphone which is fixed to the frame with mild adhesive.
      Ask FixBot
    2. Samsung Watch Active Screen Replacement, Free the barometric sensor: step 11, image 1 of 2 Samsung Watch Active Screen Replacement, Free the barometric sensor: step 11, image 2 of 2
      • Use a spudger to lift the pressure sensor up and out of its recess in the frame.
      Ask FixBot
    3. Samsung Watch Active Screen Replacement, Remove the mic array: step 12, image 1 of 1
      • Carefully remove the microphone and barometric sensor array from the frame.
      Ask FixBot
    1. Samsung Watch Active Screen Replacement, Loosen the screen adhesive: step 13, image 1 of 1
      Ask FixBot
    2. Samsung Watch Active Screen Replacement, Separate the screen and frame: step 14, image 1 of 3 Samsung Watch Active Screen Replacement, Separate the screen and frame: step 14, image 2 of 3 Samsung Watch Active Screen Replacement, Separate the screen and frame: step 14, image 3 of 3
      • Insert the opening tool under the frame where the sensor array was located.
      • Pry upwards to separate the screen from the frame.
      Ask FixBot
    3. Samsung Watch Active Screen Replacement, Remove the screen: step 15, image 1 of 3 Samsung Watch Active Screen Replacement, Remove the screen: step 15, image 2 of 3 Samsung Watch Active Screen Replacement, Remove the screen: step 15, image 3 of 3
      • Use your fingers to pull the frame off the remaining screen adhesive.
      • Clean any remaining adhesive from the frame using isopropyl alcohol (>90%) before installing the new screen.
      Ask FixBot
5 other people completed this guide.
Author
with
Tobias Isakeit
136,836 Reputation
189 Guides authored
3 Guide Comments
What replacement adhesive is needed? I think my screen is ok, but it is falling out and I need to reattach it.
Rosalie E. Morgan - Reply Share
Try searching on Ali Express or Wish, etc. I just completed a screen replacement, and the screen I got came with 2 adhesives for it.
Colm O'Sullivan - Reply Share
How do I put the mic array back in?
Mason Thomas - Reply Share
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 161
All Time: 7,279
