Up to 20% off select tools
Samsung Watch Active Screen Assembly Replacement
Views: 19K
View statistics:
Past 24 Hours:
3
Past 7 Days:
27
Past 30 Days:
118
All Time:
18,909
Comments: 25
12 comments on steps, 13 guide comments.
Go to guide comments
Completed: 17
17 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 - 55 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a cracked or broken screen assembly on your Samsung Galaxy Watch Active.
Note: Some replacement screens come as screen-only without a new frame. That's a different procedure from what's shown in this guide. If you're replacing the screen only, follow this guide instead.
    1. Samsung Watch Active Screen Assembly Replacement, Turn off the watch: step 1, image 1 of 2 Samsung Watch Active Screen Assembly Replacement, Turn off the watch: step 1, image 2 of 2
      • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
      • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
      Ask FixBot
    2. Samsung Watch Active Screen Assembly Replacement, Remove the rear screws: step 2, image 1 of 1
      • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
      Ask FixBot
    3. Samsung Watch Active Screen Assembly Replacement, Separate the back cover from the housing: step 3, image 1 of 3 Samsung Watch Active Screen Assembly Replacement, Separate the back cover from the housing: step 3, image 2 of 3 Samsung Watch Active Screen Assembly Replacement, Separate the back cover from the housing: step 3, image 3 of 3
      • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
      • Push the tip of the opening tool into the gap to separate the back cover from the housing.
      • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
      Ask FixBot
    4. Samsung Watch Active Screen Assembly Replacement, Disconnect the sensor array: step 4, image 1 of 2 Samsung Watch Active Screen Assembly Replacement, Disconnect the sensor array: step 4, image 2 of 2
      • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
      • Use a spudger to disconnect the sensor array from the motherboard.
      Ask FixBot
    5. Samsung Watch Active Screen Assembly Replacement, Remove the back cover: step 5, image 1 of 1
      • Remove the back cover.
      Ask FixBot
    1. Samsung Watch Active Screen Assembly Replacement, Disconnect the display and the mic array: step 6, image 1 of 3 Samsung Watch Active Screen Assembly Replacement, Disconnect the display and the mic array: step 6, image 2 of 3 Samsung Watch Active Screen Assembly Replacement, Disconnect the display and the mic array: step 6, image 3 of 3
      • Use a spudger to disconnect the display assembly and the microphone and pressure sensor array.
      Ask FixBot
    2. Samsung Watch Active Screen Assembly Replacement, Undo the mic tape: step 7, image 1 of 3 Samsung Watch Active Screen Assembly Replacement, Undo the mic tape: step 7, image 2 of 3 Samsung Watch Active Screen Assembly Replacement, Undo the mic tape: step 7, image 3 of 3
      • Use an opening pick to peel back the thin tape belonging to the microphone array.
      • When re-assembling make sure this tape properly sticks to the motherboard by pressing it down with the flat end of a spudger.
      Ask FixBot
    3. Samsung Watch Active Screen Assembly Replacement, Lift the core assembly: step 8, image 1 of 2 Samsung Watch Active Screen Assembly Replacement, Lift the core assembly: step 8, image 2 of 2
      • Insert an opening pick at the bottom right between the motherboard and the frame to lift up the core assembly.
      Ask FixBot
    4. Samsung Watch Active Screen Assembly Replacement, Remove the core assembly: step 9, image 1 of 3 Samsung Watch Active Screen Assembly Replacement, Remove the core assembly: step 9, image 2 of 3 Samsung Watch Active Screen Assembly Replacement, Remove the core assembly: step 9, image 3 of 3
      • Lift out and remove the core assembly.
      Ask FixBot
    1. Samsung Watch Active Screen Assembly Replacement, Loosen the mic: step 10, image 1 of 2 Samsung Watch Active Screen Assembly Replacement, Loosen the mic: step 10, image 2 of 2
      • Use a spudger to loosen the microphone which is fixed to the frame with mild adhesive.
      Ask FixBot
    2. Samsung Watch Active Screen Assembly Replacement, Free the barometric sensor: step 11, image 1 of 2 Samsung Watch Active Screen Assembly Replacement, Free the barometric sensor: step 11, image 2 of 2
      • Use a spudger to lift the pressure sensor up and out of its recess in the frame.
      Ask FixBot
    3. Samsung Watch Active Screen Assembly Replacement, Remove the mic array: step 12, image 1 of 1
      • Carefully remove the microphone and barometric sensor array from the frame.
      Ask FixBot
    1. Samsung Watch Active Screen Assembly Replacement, Screen Assembly: step 13, image 1 of 1
      • You’re left with the screen assembly.
      • Make sure to compare the new screen assembly to the old one for any parts that need to be transferred.
      Ask FixBot
17 other people completed this guide.
Tobias Isakeit
136,836 Reputation
189 Guides authored
13 Guide Comments
These instructions look very good! My screen has several cracks and I want to replace the front module. Do you have any idea where I can order one?
Jantine Stulp - Reply Share
Yes there s one on eBay for $31.76 https://www.google.com/aclk?sa=l&ai=DChc...
Dylan Austin - Reply Share
My screen was black or showing static. I disassembled and reassembled and now it's back to normal. Might have been a bad internal connection.
Benjamin Franzmayr - Reply Share
Think I have the same issue may have to try opening it. Do you still have it? Is it still good?
Simon Hall - Reply Share
this is a rather silly question, but which model is that diode on the LCD panel? I couldn't find the schematics for the screen
Thomas Jungblut - Reply Share
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 118
All Time: 18,909
