Up to 20% off select tools
Samsung WB850F Lens Assembly Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
85
All Time:
2,331
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Samsung WB850F Lens Assembly  Replacement, Control Panel: step 1, image 1 of 3 Samsung WB850F Lens Assembly  Replacement, Control Panel: step 1, image 2 of 3 Samsung WB850F Lens Assembly  Replacement, Control Panel: step 1, image 3 of 3
      • Use the Phillips #0 screwdriver to remove the six outside screws. Orientation is from the front of the camera.
      • 2 screws are located on the bottom.
      • 2 screws are located on the left side. (HDMI port)
      • 2 screws are located on the right side of the camera. (Opposite HDMI side)
      Ask FixBot
    2. Samsung WB850F Lens Assembly  Replacement: step 2, image 1 of 1
      • To remove the back screen case, use the blue opening tool to open the case up from the right side.
      Ask FixBot
    3. Samsung WB850F Lens Assembly  Replacement: step 3, image 1 of 2 Samsung WB850F Lens Assembly  Replacement: step 3, image 2 of 2
      • Use screwdriver to remove control panel screw.
      • Lift up control panel from the side where the screw was just removed.
      Ask FixBot
    1. Samsung WB850F Lens Assembly  Replacement, Lens Assembly: step 4, image 1 of 3 Samsung WB850F Lens Assembly  Replacement, Lens Assembly: step 4, image 2 of 3 Samsung WB850F Lens Assembly  Replacement, Lens Assembly: step 4, image 3 of 3
      • Remove the two screws.
      • Gently pry open metal case using Plastic tool openers.
      Ask FixBot
    2. Samsung WB850F Lens Assembly  Replacement: step 5, image 1 of 2 Samsung WB850F Lens Assembly  Replacement: step 5, image 2 of 2
      • Gently pull up on the lens connector chip to remove the lens.
      Ask FixBot
    3. Samsung WB850F Lens Assembly  Replacement: step 6, image 1 of 1
      • Insert the new lens to be replaced. Make sure you do not get this tab caught while inserting new lens.
      Ask FixBot
2 other people completed this guide.
Author
with
Jousling Vazquez
431 Reputation
4 Guides authored
USF Tampa, Team 12-4, Eyestone Spring 2016 Member of USF Tampa, Team 12-4, Eyestone Spring 2016
USFT-EYESTONE-S16S12G4
4 Members
48 Guides authored
2 Guide Comments
hi I have problem...could you please help me with my camera samsung wb850f
merdaneliyev - Reply Share
I am forward to hearing from you....
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 85
All Time: 2,331
