Up to 20% off select tools
Samsung WB850F Control Panel Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
91
All Time:
1,446
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Samsung WB850F Control Panel Replacement, Control Panel: step 1, image 1 of 3 Samsung WB850F Control Panel Replacement, Control Panel: step 1, image 2 of 3 Samsung WB850F Control Panel Replacement, Control Panel: step 1, image 3 of 3
      • Use the Phillips #0 screwdriver to remove the six outside screws. Orientation is from the front of the camera.
      • 2 screws are located on the bottom.
      • 2 screws are located on the left side. (HDMI port)
      • 2 screws are located on the right side of the camera. (Opposite HDMI side)
      Ask FixBot
    2. Samsung WB850F Control Panel Replacement: step 2, image 1 of 1
      • To remove the back screen case, use the blue opening tool to open the case up from the right side.
      Ask FixBot
    3. Samsung WB850F Control Panel Replacement: step 3, image 1 of 2 Samsung WB850F Control Panel Replacement: step 3, image 2 of 2
      • Use screwdriver to remove control panel screw.
      • Lift up control panel from the side where the screw was just removed.
      Ask FixBot
Author
with
Jousling Vazquez
431 Reputation
4 Guides authored
USF Tampa, Team 12-4, Eyestone Spring 2016 Member of USF Tampa, Team 12-4, Eyestone Spring 2016
USFT-EYESTONE-S16S12G4
4 Members
48 Guides authored
1 Guide Comment
Only problem .. Where can I buy a replacement control panel.
D Traynor - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 91
All Time: 1,446
