Samsung WB35F Rear Case Replacement
Views: 1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
96
All Time:
1,002
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will help the user to unscrew device to replace different parts of the camera using ph000 screw driver.
Tools
    1. Samsung WB35F Rear Case Replacement, Rear Case: step 1, image 1 of 3 Samsung WB35F Rear Case Replacement, Rear Case: step 1, image 2 of 3 Samsung WB35F Rear Case Replacement, Rear Case: step 1, image 3 of 3
      • The first thing to do will be unscrew all the screws using Phillips #000 Screwdriver.
      • Keep all the screws in order. Black screws goes under the bottom of camera, and the silver screws goes on the sides and inside of the camera.
      Ask FixBot
    2. Samsung WB35F Rear Case Replacement: step 2, image 1 of 2 Samsung WB35F Rear Case Replacement: step 2, image 2 of 2
      • Using the spudger, and plastic opening tool open the casing of camera.
      Ask FixBot
    3. Samsung WB35F Rear Case Replacement: step 3, image 1 of 3 Samsung WB35F Rear Case Replacement: step 3, image 2 of 3 Samsung WB35F Rear Case Replacement: step 3, image 3 of 3
      • Once you open the camera case, you will be able to work on any part of the camera.
      Ask FixBot
Sarmad Khan
549 Reputation
5 Guides authored
USF Tampa, Team 1-6, Tanski Winter 2015 Member of USF Tampa, Team 1-6, Tanski Winter 2015
USFT-TANSKI-W15S1G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 96
All Time: 1,002
