Up to 20% off select tools
Samsung WB350F Screen Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
118
All Time:
2,681
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your screen is damaged in any way, this guide will walk you through the replacement process.
    1. Samsung WB350F Screen Replacement, Rear Case: step 1, image 1 of 3 Samsung WB350F Screen Replacement, Rear Case: step 1, image 2 of 3 Samsung WB350F Screen Replacement, Rear Case: step 1, image 3 of 3
      • Remove the wristlet strap.
      • If you have difficulties use your plastic spudger. If you don't have a plastic spudger, you can also use a pen/pencil.
      Ask FixBot
    2. Samsung WB350F Screen Replacement: step 2, image 1 of 3 Samsung WB350F Screen Replacement: step 2, image 2 of 3 Samsung WB350F Screen Replacement: step 2, image 3 of 3
      • Remove five 3.2 mm screws with a Phillips #000 Screwdriver.
      • There is one silver screw on the bottom and two black screws on each side.
      • Keep the screws together for an easier re-assembly later.
      Ask FixBot
    3. Samsung WB350F Screen Replacement: step 3, image 1 of 3 Samsung WB350F Screen Replacement: step 3, image 2 of 3 Samsung WB350F Screen Replacement: step 3, image 3 of 3
      • Open the case of the camera using your plastic opening tool.
      • Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
      • If you don’t have plastic opening tools, any flat plastic object, like a used gift card, can be used as an improvised alternative.
      Ask FixBot
    4. Samsung WB350F Screen Replacement: step 4, image 1 of 1
      • Remove the plastic casing, exposing the inner workings of the camera.
      Ask FixBot
    1. Samsung WB350F Screen Replacement, Screen: step 5, image 1 of 2 Samsung WB350F Screen Replacement, Screen: step 5, image 2 of 2
      • Using your Phillips #000 Screwdriver, remove one 3.2 mm screw above the menu buttons panel.
      • Next, remove the two 3.2 mm Phillips #000 screws to the left of the menu buttons panel.
      Ask FixBot
    2. Samsung WB350F Screen Replacement: step 6, image 1 of 1
      • Move the menu button panel to the right as well as the screen.
      • Be careful because each are connected to the camera by a ribbon.
      Ask FixBot
    3. Samsung WB350F Screen Replacement: step 7, image 1 of 1
      • Remove two more 3.2 mm screws on the silver panel using your Phillips #000 Screwdriver.
      Ask FixBot
    4. Samsung WB350F Screen Replacement: step 8, image 1 of 2 Samsung WB350F Screen Replacement: step 8, image 2 of 2
      • Remove the silver panel.
      Ask FixBot
    5. Samsung WB350F Screen Replacement: step 9, image 1 of 2 Samsung WB350F Screen Replacement: step 9, image 2 of 2
      • Flip the screen back over.
      • Using the plastic open tool, flip open the black retaining plastic piece holding the larger ribbon in place.
      Ask FixBot
    6. Samsung WB350F Screen Replacement: step 10, image 1 of 2 Samsung WB350F Screen Replacement: step 10, image 2 of 2
      • Carefully detach both ribbons by gently pulling one at a time.
      • The thinner ribbon isn't secured with a connector and you are able to pull it straight out.
      • Be sure to pull gently as you do not want to break either ribbon.
      Ask FixBot
3 other people completed this guide.
Author
with
Casey Bernier
131 Reputation
1 Guide authored
1 Guide Comment
Broke my screen, bought a new one on the internet (ebay) and used this tutorial for replacement.
Good photos and every step is clear to follow
Gerald Heidrich - Reply Share
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 118
All Time: 2,681
