Samsung WB350F Rear Case Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
91
All Time:
1,372
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to remove and replace the rear case of your Samsung WB350F.
Tools
    1. Samsung WB350F Rear Case Replacement, Rear Case: step 1, image 1 of 3 Samsung WB350F Rear Case Replacement, Rear Case: step 1, image 2 of 3 Samsung WB350F Rear Case Replacement, Rear Case: step 1, image 3 of 3
      • Remove the wristlet strap.
      • If you have difficulties use your plastic spudger. If you don't have a plastic spudger, you can also use a pen/pencil.
      Ask FixBot
    2. Samsung WB350F Rear Case Replacement: step 2, image 1 of 3 Samsung WB350F Rear Case Replacement: step 2, image 2 of 3 Samsung WB350F Rear Case Replacement: step 2, image 3 of 3
      • Remove five 3.2 mm screws with a Phillips #000 Screwdriver.
      • There is one silver screw on the bottom and two black screws on each side.
      • Keep the screws together for an easier re-assembly later.
      Ask FixBot
    3. Samsung WB350F Rear Case Replacement: step 3, image 1 of 3 Samsung WB350F Rear Case Replacement: step 3, image 2 of 3 Samsung WB350F Rear Case Replacement: step 3, image 3 of 3
      • Open the case of the camera using your plastic opening tool.
      • Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
      • If you don’t have plastic opening tools, any flat plastic object, like a used gift card, can be used as an improvised alternative.
      Ask FixBot
    4. Samsung WB350F Rear Case Replacement: step 4, image 1 of 1
      • Remove the plastic casing, exposing the inner workings of the camera.
      Ask FixBot
Zachary Bourgault
101 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 91
All Time: 1,372
