Up to 20% off select tools
Samsung WB2200F Record Button Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
105
All Time:
884
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Difficult
Better Introduction
Improve this guide by completing or revising its introduction.
    1. Samsung WB2200F Record Button Replacement, Face-plate: step 1, image 1 of 3 Samsung WB2200F Record Button Replacement, Face-plate: step 1, image 2 of 3 Samsung WB2200F Record Button Replacement, Face-plate: step 1, image 3 of 3
      • Remove the 6mm screws located on the bottom and sides of the camera using the using the screw driver with the JIS size 000 head.
      Ask FixBot
    2. Samsung WB2200F Record Button Replacement: step 2, image 1 of 1
      • Remove the two 6mm screws located underneath the battery cover using the same screw driver with the JIS size 000 head.
      Ask FixBot
    3. Samsung WB2200F Record Button Replacement: step 3, image 1 of 1
      • Carefully pry the face-plate away from the body of the camera, starting from the battery compartment. It should come off without too much trouble, although it may require force.
      • Make sure to not damage any of the electronic components of the camera
      Ask FixBot
    1. Samsung WB2200F Record Button Replacement, Record Button: step 4, image 1 of 1
      • Open up the camera by removing the four 6 mm screws, that hold down the metal cover, using the screw driver with the JIS size 000 head.
      Ask FixBot
    2. Samsung WB2200F Record Button Replacement: step 5, image 1 of 1
      • Gently lift off the metal cover.
      Ask FixBot
    3. Samsung WB2200F Record Button Replacement: step 6, image 1 of 1
      • Clean out any dust or debris from the button interface.
      • Replace faulty button.
      Ask FixBot
Author
with
Rudolf Boampong
195 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 105
All Time: 884
