Tools
Introduction
Go to step 1 ↓Using this repair guide, the user will be able to replace the flash option button on the device.
Place the camera upside down on a hard surface such as a table. Make sure that the battery compartment is visible.
Remove the 6mm screws located on the bottom and sides of the camera using the using the screw driver with the JIS size 000 head.
Looking at the back of the exposed face plate, remove the four 5mm screws, that hold down the metal cover, using the screw driver with the JIS size 000 head.
