Up to 20% off select tools
Samsung WB150F Memory Card Replacement
Views: 2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
28
Past 30 Days:
122
All Time:
1,966
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
This is a streamlined guide on how to replace Samsung WB150F Memory Card. There are no tools needed for this replacement. There are many parts at risk of being damaged, ensure that you follow the procedure with care. The time needed to complete this procedure is approximately 1 to 2 minutes.
    1. Samsung WB150F Memory Card Replacement, Memory Card: step 1, image 1 of 1
      • Flip the camera upside-down so that the compartment with the battery and memory card is facing you.
      Ask FixBot
    2. Samsung WB150F Memory Card Replacement: step 2, image 1 of 2 Samsung WB150F Memory Card Replacement: step 2, image 2 of 2
      • Using your finger, slide the plastic lock-tab to the left.
      • The compartment should swing open.
      Ask FixBot
    3. Samsung WB150F Memory Card Replacement: step 3, image 1 of 1
      • The larger cavity is for the battery.
      • The small thin cavity is where the memory card goes.
      • Press lightly on the memory card to eject it from the camera.
      Ask FixBot
2 other people completed this guide.
Author
with
Keith Albergaria
214 Reputation
1 Guide authored
2 Guide Comments
Will a micro cd n an adapter fit n the camera?
Maria Elena Will - Reply Share
I was looking for max size compatability. Most folks already know how to remove and install it.
bob kavanaugh - Reply Share
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 122
All Time: 1,966
