Samsung WB150F Lens Assembly Replacement
    1. Samsung WB150F Lens Assembly Replacement, Battery: step 1, image 1 of 1
      • The location of the battery compartment can be found on the underside of the camera.
      Ask FixBot
    2. Samsung WB150F Lens Assembly Replacement: step 2, image 1 of 2 Samsung WB150F Lens Assembly Replacement: step 2, image 2 of 2
      • Have the lens of the camera face you. To open the battery compartment, slide the battery door lock towards the left. At the same time allow the battery door to swing open.
      Ask FixBot
    1. Samsung WB150F Lens Assembly Replacement, LCD Screen: step 3, image 1 of 1
      • Gather a PHO Phillips head screwdriver and a plastic wedge. If you do not have a plastic wedge like the one pictured, a credit card or a guitar pick can be used.
      Ask FixBot
    2. Samsung WB150F Lens Assembly Replacement: step 4, image 1 of 3 Samsung WB150F Lens Assembly Replacement: step 4, image 2 of 3 Samsung WB150F Lens Assembly Replacement: step 4, image 3 of 3
      • Take off the front casing by using your screwdriver to unscrew the screws circled in each of the photos (5 total).
      • The front casing can now be pulled from the camera.
      Ask FixBot
    3. Samsung WB150F Lens Assembly Replacement: step 5, image 1 of 1
      • Your camera should now look like the camera in the photo.
      Ask FixBot
    4. Samsung WB150F Lens Assembly Replacement: step 6, image 1 of 2 Samsung WB150F Lens Assembly Replacement: step 6, image 2 of 2
      • Flip the camera over and pry the back shell of the camera off with the plastic opening tool (or credit card or guitar pick). The screen-side of your camera should now resemble the camera in the second photo.
      • Note: removing the back shell does not require removing anymore screws, it should just snap off.
      Ask FixBot
    5. Samsung WB150F Lens Assembly Replacement: step 7, image 1 of 3 Samsung WB150F Lens Assembly Replacement: step 7, image 2 of 3 Samsung WB150F Lens Assembly Replacement: step 7, image 3 of 3
      • On the screen side, remove the button circuit board (outlined in red) from the camera by using the plug located in the upper right corner of the screen side.
      Ask FixBot
    6. Samsung WB150F Lens Assembly Replacement: step 8, image 1 of 3 Samsung WB150F Lens Assembly Replacement: step 8, image 2 of 3 Samsung WB150F Lens Assembly Replacement: step 8, image 3 of 3
      • Remove the metal casing by lifting up the old screen and unscrewing the 5 screws circled in the first photo.
      • The LCD screen has a ribbon going to the main circuit board, as shown in the second photo, that needs to be detached.
      • Your camera should now resemble the third photo.
      Ask FixBot
    1. Samsung WB150F Lens Assembly Replacement, Motherboard: step 9, image 1 of 3 Samsung WB150F Lens Assembly Replacement, Motherboard: step 9, image 2 of 3 Samsung WB150F Lens Assembly Replacement, Motherboard: step 9, image 3 of 3
      • Disconnect the ribbon from the flash assembly.
      • Disconnect two ribbons from the lens assembly as shown in the second picture.
      • Disconnect the ground wire from the motherboard as shown in the third picture.
      Ask FixBot
    2. Samsung WB150F Lens Assembly Replacement: step 10, image 1 of 2 Samsung WB150F Lens Assembly Replacement: step 10, image 2 of 2
      • Remove the motherboard from the camera housing.
      Ask FixBot
    1. Samsung WB150F Lens Assembly Replacement, Lens Assembly: step 11, image 1 of 1
      • Lens assembly freely detaches from housing once both ribbons are detached from the motherboard.
      Ask FixBot
Wyatt Turner
268 Reputation
3 Guides authored
IUPUI, Team 7-7, Beck Spring 2022 Member of IUPUI, Team 7-7, Beck Spring 2022
IUPUI-BECK-S22S7G7
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 76
All Time: 1,763
