Up to 20% off select tools
Samsung WB150F LCD Screen Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
27
Past 30 Days:
122
All Time:
3,199
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 40 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Parts
Tools
Introduction
Go to step 1 ↓
This guide will teach someone how to change the LCD screen on the back of a Samsung WB150F camera.
    1. Samsung WB150F LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
      • Gather a PHO Phillips head screwdriver and a plastic wedge. If you do not have a plastic wedge like the one pictured, a credit card or a guitar pick can be used.
      Ask FixBot
    2. Samsung WB150F LCD Screen Replacement: step 2, image 1 of 3 Samsung WB150F LCD Screen Replacement: step 2, image 2 of 3 Samsung WB150F LCD Screen Replacement: step 2, image 3 of 3
      • Take off the front casing by using your screwdriver to unscrew the screws circled in each of the photos (5 total).
      • The front casing can now be pulled from the camera.
      Ask FixBot
    3. Samsung WB150F LCD Screen Replacement: step 3, image 1 of 1
      • Your camera should now look like the camera in the photo.
      Ask FixBot
    4. Samsung WB150F LCD Screen Replacement: step 4, image 1 of 2 Samsung WB150F LCD Screen Replacement: step 4, image 2 of 2
      • Flip the camera over and pry the back shell of the camera off with the plastic opening tool (or credit card or guitar pick). The screen-side of your camera should now resemble the camera in the second photo.
      • Note: removing the back shell does not require removing anymore screws, it should just snap off.
      Ask FixBot
    5. Samsung WB150F LCD Screen Replacement: step 5, image 1 of 3 Samsung WB150F LCD Screen Replacement: step 5, image 2 of 3 Samsung WB150F LCD Screen Replacement: step 5, image 3 of 3
      • On the screen side, remove the button circuit board (outlined in red) from the camera by using the plug located in the upper right corner of the screen side.
      Ask FixBot
    6. Samsung WB150F LCD Screen Replacement: step 6, image 1 of 3 Samsung WB150F LCD Screen Replacement: step 6, image 2 of 3 Samsung WB150F LCD Screen Replacement: step 6, image 3 of 3
      • Remove the metal casing by lifting up the old screen and unscrewing the 5 screws circled in the first photo.
      • The LCD screen has a ribbon going to the main circuit board, as shown in the second photo, that needs to be detached.
      • Your camera should now resemble the third photo.
      Ask FixBot
To reassemble your device, follow steps 1-5 in reverse order.
7 other people completed this guide.
Author
with
Patrick Gouveia
112 Reputation
1 Guide authored
1 Guide Comment
This guide is excellent. I bought a used wb150f which powered up, but did not respond to the control buttons on the back. Looking at these great high-res pix, I could see there was a mating connector between the button board and the main board, so I hoped I could re-seat that connector and it would start working. Opening it up was easy, but step 4 required me to separate the case slightly at the edges before I could get a gap to pry into. When I got the case off, I could see that the entire connector had come off the button board, and to fix it would be impossible due to the tiny pitch of the pins. Still, without this guide I would never have known for sure the issue. Back to Goodwill you go!
Steve Duncan - Reply Share
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 122
All Time: 3,199
