Up to 20% off select tools
Samsung UBD-M8500 Outer Shell Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
8
Past 30 Days:
64
All Time:
495
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If your Samsung UBD-M8500 is not functioning well and you've already tried the available troubleshooting advice. You might need to replace something inside the device, which requires removing and or replacing the outer shell of the device. Here is how to replace the outer shell of your Samsung UBD-M8500.
    1. Samsung UBD-M8500 Outer Shell Replacement, Outer Shell: step 1, image 1 of 1
      • On the back of the device, remove the three 8.1 mm screws with a Phillips #1 screwdriver.
      Ask FixBot
    2. Samsung UBD-M8500 Outer Shell Replacement: step 2, image 1 of 1
      • From the back lift the case of the device upwards then forward, releasing the clips from the front.
      Ask FixBot
    3. Samsung UBD-M8500 Outer Shell Replacement: step 3, image 1 of 1
      • Using two fingers in a pinching motion, release the wire from the clip that is attached to the outer shell and disconnect it.
      • Do not pull on the wires.
      Ask FixBot
    4. Samsung UBD-M8500 Outer Shell Replacement: step 4, image 1 of 1
      • Remove the cover of the device.
      Ask FixBot
Author
with
Enrique Howell
401 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 64
All Time: 495
