Samsung UBD-M8500 Fan Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
64
All Time:
562
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If you're encountering overheating issues or unusual noise from your Samsung UBD-M8500 Blu-ray player, it might be time to replace the internal fan using a Phillips #1 screwdriver head. The fan is a critical component responsible for maintaining optimal operating temperatures and ensuring the longevity of your device. This step-by-step guide will assist you in the seamless replacement of the fan.
Parts
Tools
    1. Samsung UBD-M8500 Fan Replacement, Outer Shell: step 1, image 1 of 1
      • On the back of the device, remove the three 8.1 mm screws with a Phillips #1 screwdriver.
      Ask FixBot
    2. Samsung UBD-M8500 Fan Replacement: step 2, image 1 of 1
      • From the back lift the case of the device upwards then forward, releasing the clips from the front.
      Ask FixBot
    3. Samsung UBD-M8500 Fan Replacement: step 3, image 1 of 1
      • Using two fingers in a pinching motion, release the wire from the clip that is attached to the outer shell and disconnect it.
      • Do not pull on the wires.
      Ask FixBot
    4. Samsung UBD-M8500 Fan Replacement: step 4, image 1 of 1
      • Remove the cover of the device.
      Ask FixBot
    1. Samsung UBD-M8500 Fan Replacement, Fan: step 5, image 1 of 2 Samsung UBD-M8500 Fan Replacement, Fan: step 5, image 2 of 2
      • Remove the two screws on the back of the device, using a Phillips #1 screwdriver.
      Ask FixBot
    2. Samsung UBD-M8500 Fan Replacement: step 6, image 1 of 2 Samsung UBD-M8500 Fan Replacement: step 6, image 2 of 2
      • Grip the white fan connector and pull it directly out if its port.
      Ask FixBot
    3. Samsung UBD-M8500 Fan Replacement: step 7, image 1 of 1
      • Lift the fan out of the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 64
All Time: 562
