Samsung UBD-K8500 Disc Tray Replacement
  1. Samsung UBD-K8500 Disc Tray Replacement, Top Panel: step 1, image 1 of 2 Samsung UBD-K8500 Disc Tray Replacement, Top Panel: step 1, image 2 of 2
    • Remove the six 10 mm screws from the back of the unit using a Phillips #0 screwdriver.
    Ask FixBot
  2. Samsung UBD-K8500 Disc Tray Replacement: step 2, image 1 of 2 Samsung UBD-K8500 Disc Tray Replacement: step 2, image 2 of 2
    • Carefully lift up the top panel.
    • There is a cables that must be disconnected before completely removing the panel.
    • Detach the cable connecting the top panel to the motherboard.
    • Take the top off and set it to the side.
    Ask FixBot
  3. Samsung UBD-K8500 Disc Tray Replacement, Disc Tray: step 3, image 1 of 2 Samsung UBD-K8500 Disc Tray Replacement, Disc Tray: step 3, image 2 of 2
    • Find the blue tabs of the ribbon connectors, and gently pull them both out.
    Ask FixBot
  4. Samsung UBD-K8500 Disc Tray Replacement: step 4, image 1 of 2 Samsung UBD-K8500 Disc Tray Replacement: step 4, image 2 of 2
    • Remove the four 8 mm screws from the disc drive using a Phillips #0 screwdriver.
    Ask FixBot
  5. Samsung UBD-K8500 Disc Tray Replacement: step 5, image 1 of 2 Samsung UBD-K8500 Disc Tray Replacement: step 5, image 2 of 2
    • Gently remove the disc tray.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 22
All Time: 337
