Samsung UBD-K8500 Case Fan Replacement
  1. Samsung UBD-K8500 Case Fan Replacement, Top Panel: step 1, image 1 of 2 Samsung UBD-K8500 Case Fan Replacement, Top Panel: step 1, image 2 of 2
    • Remove the six 10 mm screws from the back of the unit using a Phillips #0 screwdriver.
    Ask FixBot
  2. Samsung UBD-K8500 Case Fan Replacement: step 2, image 1 of 2 Samsung UBD-K8500 Case Fan Replacement: step 2, image 2 of 2
    • Carefully lift up the top panel.
    • There is a cables that must be disconnected before completely removing the panel.
    • Detach the cable connecting the top panel to the motherboard.
    • Take the top off and set it to the side.
    Ask FixBot
  3. Samsung UBD-K8500 Case Fan Replacement, Case Fan: step 3, image 1 of 2 Samsung UBD-K8500 Case Fan Replacement, Case Fan: step 3, image 2 of 2
    • Pinch and gently remove the connector from its socket.
    Ask FixBot
  4. Samsung UBD-K8500 Case Fan Replacement: step 4, image 1 of 2 Samsung UBD-K8500 Case Fan Replacement: step 4, image 2 of 2
    • Remove the case fan.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 240
