Samsung UBD KM85C Outer Shell Replacement
    1. Samsung UBD KM85C Outer Shell Replacement, Outer Shell: step 1, image 1 of 1
      • On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
      Ask FixBot
    2. Samsung UBD KM85C Outer Shell Replacement: step 2, image 1 of 2 Samsung UBD KM85C Outer Shell Replacement: step 2, image 2 of 2
      • From the back, lift the case upwards away from the unit then forwards, releasing the prongs on the front.
      Ask FixBot
    3. Samsung UBD KM85C Outer Shell Replacement: step 3, image 1 of 3 Samsung UBD KM85C Outer Shell Replacement: step 3, image 2 of 3 Samsung UBD KM85C Outer Shell Replacement: step 3, image 3 of 3
      • There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it.
      Ask FixBot
    4. Samsung UBD KM85C Outer Shell Replacement: step 4, image 1 of 1
      • Remove the cover from the device.
      Ask FixBot
3 other people completed this guide.
Breanna Ainsworth
258 Reputation
1 Guide authored
Baylor, Team S2-G1, Johnson Spring 2018 Member of Baylor, Team S2-G1, Johnson Spring 2018
BU-JOHNSON-S18S2G1
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 523
