Samsung U28E510 Jog Button Replacement
    1. Samsung U28E510 Jog Button Replacement, Jog Button: step 1, image 1 of 3 Samsung U28E510 Jog Button Replacement, Jog Button: step 1, image 2 of 3 Samsung U28E510 Jog Button Replacement, Jog Button: step 1, image 3 of 3
      • Start by removing the screen bezel.
      • Use a pair of spudgers to pry between the bezel and the rest of the monitor.
      • Ideally use plastic tools as this step could damage the edges of the screencover.
      • lay monitor on its back and pull off screen cover.
      Ask FixBot
    2. Samsung U28E510 Jog Button Replacement: step 2, image 1 of 2 Samsung U28E510 Jog Button Replacement: step 2, image 2 of 2
      • Flip the monitor over so that it is facedown.
      • remove the single screw in the middle using a #2 Phillips screwdriver.
      • Remove the backing to reveal the Jog Button.
      Ask FixBot
    3. Samsung U28E510 Jog Button Replacement: step 3, image 1 of 1
      • Disconnect signal cable to power supply board.
      • Remove and replace jog button.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Ensure the bezel completely snaps in place all around monitor.
3 other people completed this guide.
Jake Ritter
106 Reputation
1 Guide authored
Cal Poly, Team S11-G1, Banghart Winter 2018 Member of Cal Poly, Team S11-G1, Banghart Winter 2018
CPSU-BANGHART-W18S11G1
4 Members
36 Guides authored
5 Guide Comments
i have a samsung u28d590d and it works just the same. simple and easy as the guide says.
joshsc2 - Reply Share
Does anyone have the part number or where I can buy the new jog button?
Kyle Gulliford - Reply Share
“bn96-32135b “
Gary Deon - Reply Share
this is the part number i found BN96-32135B
the button on my monitor wasn't working anymore - pressing it didn't do anything. So I decided to follow this great guide. When I removed the top of the button and put it on again, I noticed that it worked again. Seems that there had been just to many dust.
Thanx for this guide!
Ralf D. Müller - Reply Share
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 112
All Time: 9,071
